Old 10th October 2009, 15:47   #16
Sn1p3r's Avatar
Thanked: 230 Times
I think the title needs a new version. All posts are repetitive as OBD2 is updgrade on OBD1. Now the thread has started turning towards ECU and soon it will be chips taking over
Sn1p3r is offline   Reply With Quote
Old 12th October 2009, 20:00   #17
ImmortalZ's Avatar
Thanked: 312 Times
Originally Posted by pranavt View Post
Piggybacks on Honda OBD1 ECUs are useless, as the ECUs can be chipped and made to behave exactly like full-blown standalones with datalogging, remapping et al
OBD2 ECUs from Honda can also be made into full blown standalone-killing ECUs with magic from Hondata.
Old 12th October 2009, 22:48   #18
pranavt's Avatar
Thanked: 274 Times
Not all of them though. And Hondata costs a packet. For that kind of money, you can probably get a RD ECU.
Old 19th October 2009, 13:34   #19
ImmortalZ's Avatar
Thanked: 312 Times
Eh?
Hondata is in the USD 1000 range while comparable standalones from AEM or MOTEC cost north of the 4k mark.
It might be expensive, but it costs peanuts compared to the alternatives.
As far as RD goes, I don't know the feature sets, so I can't comment.
Old 20th October 2009, 06:44   #20
chetanhanda's Avatar
Thanked: 44 Times
Originally Posted by Sprucegoose View Post
1> So is it possible to use another ECU?
Like if, hypothetically, i get an RD ECU, I will have to get one that is designed for my OHC [or for a certain set of similar engines.]
2> I've read alot about people switching over from OBD2 ECUs to chipped OBD1 ECUs
3> So by switching from on OBD2 to an OBD1 ECU, the only thing one is doing is restricting the amount of information that you can check?
These things are pretty complicated, if u get a RD ECU probably u will get better support for tuning as compared to Hondata..
Maybe you should think of the 1st hand tuning support also..
chetanhanda is offline   Reply With Quote
What are the advantages of clip-on handlebars ? mithun Motorbikes 14 10th March 2010 20:15
Fitting Gas - Advantages & Disadvantages Surprise Modifications & Accessories 43 20th August 2009 10:10
Advantages of Baleno over Accent ravitsp Sedans 38 6th December 2007 01:16
Advantages of Low profile tyres ??? roopakr Tyre & Alloy wheel Section 3 30th April 2007 16:13
