Old 13th October 2009, 22:58   #76
ported_head's Avatar
Renault ran a V6 camless engine in F1 many years back. Since then they ran it on some road/concept car too. However, the speculation seems to suggest that the current F1 cars still run camshafts. However, it's all very tight lipped. The pneumatic actuation is a replacement for mechanical valve springs only. The easiest way to go about varying engine braking via selector would seem like ECU mapping only. Decel cut-off is easier to vary.
However, I was reading around, and it seems that we are taking engine braking in the literal sense, and that it's application in F1 maybe slightly different. It seems, that with the loss of traction control systems in 2008, out went Engine Braking System also. The car pictured here is a 2005/6 car. What the EBS does is monitor wheel lock up under braking and minimises it in conjunction with the traction control system. Though I don't think it varies braking torque on the wheels, it could vary the torque going to the wheels, indirectly varying the amount of engine braking. Some even seem to suggest a pulsating electronic actuation of the clutch so as to minimise wheel lock up.
ported_head is offline   Reply With Quote
Old 1st March 2010, 23:08   #77
im_srini's Avatar
Thanked: 368 Times
Infractions: 0/1 (5)
Post F1 rear suspension tech
Originally Posted by ported_head View Post
Attachment 206922
When one wheel side hits, say a bump, the pushrod pushes against the bell crank lever (A), which actuates the hydraulic damper (B) shaft, in tandem with the spring in A. This also causes rotation of the the equal bias linkage, which in turn rotates the torsion bar. The torsion bar also has the facility to move fore and aft, when the central shock absorber (D), compresses.
A nice animation of what's stated above...
im_srini is offline   Reply With Quote
2016 Formula 1 Austrian GP – Red Bull Ring jfxavier Int'l Motorsport 45 6th July 2016 17:57
Red Bull's threat to pull out from Formula 1 jraj Int'l Motorsport 30 17th December 2015 06:37
Red Bull Racing Cans: Chance to visit the Red Bull Racing HQ in Milton Keynes varun_patra Indian Motorsport 0 22nd July 2011 15:51
Red Bull F1 car @ Bandra Worli Sealink in Mumbai. UPDATE: Report & Videos pg7 onwards Dippy Int'l Motorsport 150 2nd November 2009 12:41
