Old 14th October 2009, 17:11   #1
car'zy's Avatar
Default Cedia - Upsized tyres scrapping the insides
I had to drive to Mangalore and back couple of times over the last 2 weeks, each time with 4+1 passengers and a little bit of luggage. The rear tyres scraped the body constantly. Im told this is because I'm running on upsized tyres. (I only upgraded the stock to 205/60 R15).
I had this problem with my front tyres as well sometime back, where the tyres would scrap the bumper on curves, I cut off the insides of the bumper skirts a wee bit and it was fixed. Now the problem is with the rear tyres hitting the top insides.
Any suggestions? Does it mean a weak suspension?
car'zy is offline   Reply With Quote
Old 14th October 2009, 17:32   #2
Psycho's Avatar
Thanked: 95 Times
You could try spacers or harder springs (which would be difficult to find as most aftermarket ones are the lowering types)
Old 15th October 2009, 17:42   #3
Thanked: 103,522 Times
Therein lies the problem. Your stock tyre (195/60/15) had a diameter of 614.93 mm, your upgraded tyre has a diameter of 626.87 mm. Translated, its taller than the stock tyre size and is leading to your rubber scraping the body parts.
Old 15th October 2009, 19:11   #4
vdiatech's Avatar
u could try adjusting the wheel arch liners a bit ( roll / push ( not sure of the term!) upwards) . This might help
vdiatech is offline   Reply With Quote
Old 15th October 2009, 19:13   #5
nitrous's Avatar
Thanked: 285 Times
This isn't 'bottoming out'.
Old 15th October 2009, 19:14   #6
beejay's Avatar
Thanked: 109 Times
These are things which you should live with when you upsize. I had upsized my wagonR and faced the same problem. I bent the inner seam of the rear fenders a bit. This did not solve the problem completely, however was much better.
How much has you car run?
beejay is offline   Reply With Quote
Old 15th October 2009, 19:19   #7
reignofchaos's Avatar
Thanked: 1,302 Times
Bottoming out is when the underbody hits the road. Its quite surprising though - I had 205/60 R15 until recently and never had a problem even with 5 people and luggage.
You might want to get your suspension checked.
Maybe the springs have softened due to use. Some tightening might help
reignofchaos is online now   Reply With Quote
Old 15th October 2009, 23:20   #8
gaurav_chopra04's Avatar
Thanked: 534 Times
I always wondered if the 205/60's on cedia would scrape the body, I guess its its better to upgrade to 205/55s. Ground clearance will definately be affected but only marginally which I believe is managable.
In your case carzy, check with the service station guys, they may come up with some solution, get the suspension checked as ROC quoted, than letting your local mechanic fiddle with the suspension. I dont think suspension can go weak so early, but still you never know. Also rear suspension last more than the front one. I expect it to last good for atleast 7-8 years.
gaurav_chopra04 is offline   Reply With Quote
Old 22nd October 2009, 18:15   #9
car'zy's Avatar
Thanks guys for your perspectives. I thought it was because of the diameter difference, but then had a doubt as I havent seen any fellow Tbhp/Cedia owners having problems with the same tyres. My car has just run 25K, nonetheless, I will get the suspension checked with my service station shortly. Thanks, again!
Old 15th March 2010, 18:25   #10
mindbender's Avatar
Have you been able to solve the problem yet? I am also planning to upgrade to the same size of tyres, so wanted to know what the problem might be.
mindbender is offline   Reply With Quote
Correct Tyre Pressure For Upsized Tyres Xehaust Tyre & Alloy wheel Section 4 2nd April 2018 10:32
Upsized my Civic's tyres. Now scraping under load! keertan Modifications & Accessories 14 8th June 2011 14:35
Can tyres be upsized before RTA inspection? Schnellster Tyre & Alloy wheel Section 16 9th October 2009 22:09
upsized tyres for Honda City (idsi) columbus Tyre & Alloy wheel Section 0 15th December 2008 14:11
Ikon Rocam engine-Insides revealed (with animation)! vezj420 Technical Stuff 14 7th October 2008 14:30
