Old 16th October 2009, 10:34   #16
foby.sebastian's Avatar
Thanked: 1,105 Times
Originally Posted by jav View Post
Once the engine has turned on the battery indicator has to turn off (which means the battery is getting charged by the alternator) if it still remains lit even after starting the engine it means the battery is getting drained and there is a problem in the charging system.
I have a similar issue in my maruthi 800
when I start the vehicle The battery indicator will be on , but after some time , If I accelerate the vehicle well the battery light will turn off.
I thought it can be an issue with the battery , we got a brand new battery now but the issue still persists.
Can some one throw some light in to this issue ?
foby.sebastian is offline   Reply With Quote
Old 16th October 2009, 11:23   #17
karizma_devil's Avatar
Thanked: 16 Times
@foby if the light fades when you accelerate then it is the alternator diode/ rectifier.
PLease check it with a non M.a.s.s , may be a Lucas service centre near you.
karizma_devil is offline   Reply With Quote
Old 16th October 2009, 11:44   #18
Thank you mate , I am very weak in the eletrical side of a car , oops even in my engineering studies too
Old 16th October 2009, 11:55   #19
jav
I think the alternator is getting weak and/or it can be the diode.
jav is offline   Reply With Quote
Old 16th October 2009, 11:59   #20
Speed Pujari's Avatar
Thanked: 389 Times
Apparantly the battery is getting charged bcoz the battery indicator goes off after starting the car . The voltmeter gives a 13.88 with the new battery after I turn on the car (Is this normal?). Since the battery is new it needs a full time charging to get to full power pace.
The lights were going off after starting the car even when I took the car off from prerana yesterday i.e. with the old battery. I was sure about the battery problem since even after driving for long distance the car could crank only once max, no power was left for second crank. Meaning the battery was getting charged to some extent. Prerana guys charged the battery externally for more than 5 hours too.
Also yesterday the battery was very hot when the battery shop guy opened the bonnet to check them up. Is that also a sign of aged battery? At least that is what he told me.
Initially when the problem surfaced then the battery indicator was not coming up even before turning the keys on. I think that was a case of current leakage which was fixed by prerana guys (I dont know to what extent this is true) bcoz later the lights started to show up with the old as well as new battery.
So i think something was fixed by prerana guys which was screwed up by Hariprasad guys.
After this incidence I am kinda sceptical and scared to go to any other service station, but still I feel to give BOSCH service a try. My car is still due service.
I am a little happy with prerana bcoz at least they gave some level of QOS, they showed their concern, ownership and care when I was stranded. It was completely unlike Hariprasad who charged 500 bucks for screwing up the things and a sense of washing hands away after delivering the car.
Prerana guys charged me only 250 bucks.
So altogether I spent approx 5500 bucks to buy battery, labour cost, fuel and hell lot of tension and stress.
Speed Pujari is offline   Reply With Quote
Old 16th October 2009, 12:11   #21
lohithrao's Avatar
Thanked: 163 Times
Speed, i would suggest that you get your car checked once at "Concorde" Hosur road.
i wont dare to take my Adventure anywhere else.
lohithrao is online now   Reply With Quote
Old 16th October 2009, 12:28   #22
Thanked: 665 Times
Although its a crude method, one quick way of checking whether the alternator is supplying power to charge the batteries is to get the car in front of a wall with the headlights ON and slightly rev the engine.
If you see the headlights becoming a bit more intensive/brighter during the revving, it gives an indication that the alternator is providing some charge to the battery.
In a completely dead alternator, there would be no difference in the headlight intensity while pressing the accelerator.
Also as mentioned in the previous posts, push starting any car with a catalytic converter could permanently damage the same and prove costly.
for_cars1 is offline   Reply With Quote
Old 16th October 2009, 12:39   #23
Thanked: 389 Times
Concorde, Prerana, they are all blood brothers! ..
I got them checked with a voltmeter which goes up after starting the car. Vaguely I remember it was 13.2 before starting and 13.88 after starting the car. That means alternator is working fine.
Also I got the alternator completely checked at prerana. Its working fine.
Now since the battery is replaced, I need to observe the car for next few days for the behavior. Lets see.
Old 16th October 2009, 12:50   #24
lohithrao's Avatar
Thanked: 163 Times
Well am not sure how close are they but "Concorde" has succeded in fixing all the issues till now without any fuss! its more then a year am still stuck with them, though the drive is quiet long. Marathalli to Hosur road but i dont mind it.
Old 16th October 2009, 13:05   #25
trrk's Avatar
Thanked: 13 Times
For starters, check the alternator belt. If it is slightly loose, the idle RPM may not generate enough voltage from the alternator for the light to go off.
trrk is offline   Reply With Quote
Old 16th October 2009, 15:20   #26
Alter_Ego's Avatar
Thanked: 98 Times
Both prerana and Concorde has excellent workmanship and skilled mechanics.
But my personal experience with prerana has been bitter as they quoted 25K to make my tata safari gearbox more slick.
Concorde did it for 3K and till date I have no complains.Its been 4 months now.
Alter_Ego is offline   Reply With Quote
Old 16th October 2009, 16:12   #27
Thanked: 389 Times
I am not very sure about any of the Fiat-Tata service centers including prerana. Till date whatever they have done was only based on guesswork. They are more good in talking sweet.
But this time I am seeing whatever they have said or done is upto the mark or not. Otherwise I'll have to be a lab monkey again next time (trying Bosch or Concorde).
Old 16th October 2009, 21:21   #28
vipul_singh's Avatar
Thanked: 256 Times
@speedpujari: Now that you have got your battery replaced, do check the voltage across terminals with the engine idling and with all the usual electrical loads. Should be over 12 volts. If not, then I would suspect an electrical leak like Karizma devil described.
One way of checking if the battery is getting *sufficiently* charged (merely getting charged is not good enough) when the engine is idling is:
Start engine, turn on electrical loads(lights, A/C etc), turn on interior light (either by opening the door, or by moving the interior light to 'ON' position).
Now, while concentrating on the interior light, turn the engine off (all the electrical loads would also turn of automatically in the Palio). If the interior light grows dimmer, then the battery was being charged even with all the electrical loads on.
The idea behind this test is:
(System voltage with electrical loads + engine idling) should be greater that (system voltage without electric loads + engine off)
On the part about the sensors, let me get back to NOIDA in a few days and I would try to find out the correct test procedures for the said sensors.
vipul_singh is offline   (1) Thanks Reply With Quote
JVC+KW-XR810 or something else agbenny In-Car Entertainment 1 1st May 2011 22:30
1L Budget: Palio GTX or something else? vcash Hatchbacks 64 14th January 2011 11:15
Alto or Santro or something else for a new driver mukundsb Hatchbacks 34 19th June 2008 00:53
Hiquphon tweeters ow2 or something else. amangujral06 Gadgets, Computers & Software 9 6th June 2008 19:48
