Old 17th October 2009, 23:13   #16
McLaren Rulez's Avatar
Thanked: 474 Times
^Thanks for that! A wealth of info in there
McLaren Rulez is offline   Reply With Quote
Old 18th October 2009, 08:02   #17
Thanked: 30 Times
The multijet is diesel technology, whilst MPFI is for petrol.The biggest difference is that : mulitjet is based on direct injection of fuel in the combustion chamber during the compression stroke.In MPFI, injectors are located in the upstream of intake manifold. In the intake stroke , as intake valve opens,injectors inject fuel and air + fuel mixture reaches in the combustion chamber, in the intake stroke thus in-direct injection.In comparison only air reaches in the combustion chamber of diesel multijet.
Someone here said, that just because there is a common rail, thus its enables them to identify it as diesel engine. Not, true i would say. I have seen an accumulator or rail in MPFi cars too.
ritedhawan is offline   Reply With Quote
Old 19th October 2009, 01:30   #18
Manas's Avatar
Originally Posted by kuttapan View Post
... start-up times and exhaust smoke are reduced, noise levels and vibration are lowered to ensure a quieter drive and improved passenger comfort, and both fuel consumption and emissions are significantly reduced...
Siemens is another major player in high pressure common rail Direct injection systems. The glow plugs offered by Siemens (used in Mercedes) has a pressure sensor right near their tip (as against body mounted knock-detection sensors on other engines)... This significantly improves knock detection and contributes to a quieter engine performance.
"Multijet" derives its name from the multiple-jets that the piezo injectors deliver as explained before. These injectors spray the diesel AGAINST a very high pressure developed during the compression stroke of the cycle.
MPFI Injectors, on the other hand, inject during the intake stroke of the cycle. Further, as gasoline is more easily atomised than diesel, High pressure injection is not required.
However, GDI (Gasoline Direct Injection) technology is the next step in Gasoline engines. I'm not sure if it is available in any production vehicle. AVL had developed a prototype Engine named "Spectros" with GDI.
Manas is offline   Reply With Quote
Old 19th October 2009, 16:09   #19
kuttapan's Avatar
Thanked: 12 Times
The new Holden models feature SIDI. Spark Ignition direct injection, basically the same as what you said. They have increased power and fuel efficiency at the same time, while using a smaller mill. WOW, I should say. Waiting for the car to be featured at rentals, to get hold of one.
kuttapan is offline   Reply With Quote
Old 22nd October 2009, 08:34   #20
Thanked: 40 Times
Dear All (Especially Kutappan),
Thanks so much for the classes on the subject i had doubts.
Would you also let me know on E F I - Electronic fuel Injection please.
nandans2005 is offline   Reply With Quote
Old 22nd October 2009, 08:48   #21
Ravveendrra's Avatar
Thanked: 405 Times
PD, CDI, Multijet etc. are all extensively discussed in the thread "Pumpe-Duse diesel technology as against better known CRDi" at: http://www.team-bhp.com/forum/techni...ighlight=Pumpe (Pumpe-Duse diesel technology as against better known CRDi).
Cheers,
Note to mods: Perhaps this thread can be merged with the older one.
Ravveendrra is offline   Reply With Quote
Whats double clutching & whats the reason to use it _Crazi4Speed_ Technical Stuff 109 25th February 2016 08:49
Difference Between MPFI/Carburetor LPG Kit ? gameonrwind Modifications & Accessories 4 6th March 2008 14:52
Mags & Alloys - Whats the difference? hot_rod Tyre & Alloy wheel Section 25 8th April 2005 18:42
