Old 17th October 2009, 11:56   #1
Default Wagon R : Sound in Rear shocks when moves from rest
Hi All,
I have a Wagon R about 6-7 years old. Past few weeks there is a peculiar problem which I am facing : whenever I start the car and it starts to move there is a sound from the back of the car , it stops once the car has started moving.
I opened the rear boot doorand tried pressing the car and there was sound from rear shockups.
What should I do , any idea . How much is the cost involved servicing rear shocks ?
SIMKIM is offline   Reply With Quote
Old 17th October 2009, 20:59   #2
Thanked: 149 Times
Sure that this is the shocks and not under greased brake pads?
Old 18th October 2009, 14:56   #3
Thanked: 103,473 Times
Most definitely the hand brake + slight jamming. Bet you use the handbrake when the car is parked, right?
Old 18th October 2009, 16:16   #4
Knight Rider's Avatar
Thanked: 11 Times
Had the same issue in my alto, as @GTO said, it was the handbrake getting jammed.
Knight Rider is offline   Reply With Quote
Old 18th October 2009, 20:40   #5
sudharma's Avatar
Hand brakes binding.
sudharma is offline   Reply With Quote
Old 19th October 2009, 10:37   #6
sumeethaldankar's Avatar
Thanked: 1,158 Times
Is the car hesistant to move the moment you start?If so then you probably give it some more gas then there probably will be a sound like a thud and you move on.
If the sitution is like described above then as other's have said it is case of jamming rear brakes.To be sure , next time you come home do not engage the parking brake overnight and check again the next morning.
If there is no sound and no hesitancy of the car then you can be sure it is the handbrake issue.You will probably need to get the rear drums cleaned.
When i was having a similar problem i was advised by the mechanic not to engage the parking brake overnight especially during the rainy season.So unless i am not parking on a slope etc overnight i leave the handbrake disengaged.
sumeethaldankar is online now   Reply With Quote
Old 19th October 2009, 10:46   #7
Thanks all for your advice.
I dont use handbrakes much . For overnight parking I use gears but maybe the sound is from brakes only. Sometimes when I brake my ca during the signals there is a thud from rear .
Old 21st October 2009, 19:20   #8
Thanked: 149 Times
Well guys, nice to know the diagnosis, but what is the cure?? WIll greasing some part help?
I too am having the irritating issue. Will go away after a few hundred meters of driving.
Old 21st October 2009, 19:43   #9
SPEEDY_RACER's Avatar
Thanked: 172 Times
Hi All,
even i had the same peculiar problem in my wagon R but hte sound was from front.
so when got it checked he told that the Ball joints and some other have become very weak and end up in changing the entire sets.
finally its it in track now.
SPEEDY_RACER is offline   Reply With Quote
Old 21st October 2009, 21:15   #10
Thanked: 54 Times
I doubt that you have worn out rubber bushes on the shocks . The car being 6-7 yrs old ,the bushes must have given away if you have not changed the suspesnion bush kits . try to get the bushes checked .
Rear shocks for fiero F2? ramki067 Motorbikes 4 23rd July 2010 21:51
Height adjustable head-rest for rear seat Podilam Modifications & Accessories 4 14th December 2009 16:16
M800 moves by itself A.R Technical Stuff 12 3rd August 2008 20:22
Fiat moves back into the black rahul_intlad The International Automotive Scene 12 23rd February 2007 09:40
Santro rear shocks Xfade Technical Stuff 4 12th January 2007 13:05
