Old 1st June 2010, 22:21   #166
Zen2001's Avatar
Thanked: 18 Times
Originally Posted by sam_hyd View Post
If you want 12", go for Maruti original Alto rims. They are a perfect match for zen. if you want 13", then go for Maruti original old Wagon R rims.
Thanks. Do you have any idea of the prices of both? Just so that I'm not taken for a ride!
Also any ideas if the old rims can be exchanged for new ones and what they would fetch? They have run 128500km and have widened rim holes but otherwise not dented/damaged or rusted.
Originally Posted by Jaggu View Post
If you want better ride stick to 12" for a better handling steering go with 13", as long as you keep the overall dia same error etc will not be an issue.
Mine is a non Power Steering version; have run 128600km on 145/80 R12 (MRF & Apollo).
What effect will R13 rims have on steering effort/safety of cornering?
Last edited by Jaggu : 2nd June 2010 at 13:17. Reason: Back to back posts, please use Multi (Quote +) instead, Thanks
Zen2001 is offline   Reply With Quote
Old 2nd June 2010, 11:28   #167
NOS Power's Avatar
Thanked: 55 Times
Then Zen originally came with 13 inchers.
With 13 inchers the steering will be slightly heavier during parking, while on the move you will admire the surefootedness of its handling. An ideal upsize will be 155/65 R13's.
NOS Power is offline   Reply With Quote
Old 2nd June 2010, 13:11   #168
Zen2001's Avatar
Thanked: 18 Times
Thanks. Not to be picky, but mine came with 145/80 R12 as stock (back in Jan 2001). Even if someone smells a rat there, I guess its 10 years too late!
Old 2nd June 2010, 14:15   #169
speedsatya's Avatar
Thanked: 710 Times
MPFI Zens did come with 12 inch tires.The 2 door Carbon and Steel MPFI version though came with 13 inch tires.
The 145/70r13 on previous zens were prone to bent rims and this was reason MUL introduced 12 inchers.
speedsatya is offline   Reply With Quote
Old 3rd June 2010, 10:58   #170
devrajman's Avatar
Thanked: 116 Times
Im seeing something odd from quiet sometime.
My '99 Carb Zen idling RPM drops to ~600 from ~850 when I turn on the headlight!
I have 100/90w philips rally lights installed. Is this the reason?
Also, as per my assumption, rpm should rise when demand increases.
devrajman is offline   Reply With Quote
Old 3rd June 2010, 11:19   #171
NOS Power's Avatar
Thanked: 55 Times
Did you get a relay installed? Then check its wiring, could be badly installed.
Also reasons could be a weak battery and or a weak alternator.
Old 3rd June 2010, 11:28   #172
devrajman's Avatar
Thanked: 116 Times
Yes relay is installed. I will checked its wiring.
Also, i will get my battery and alternator checked soon.
Old 3rd June 2010, 14:21   #173
archat68's Avatar
Thanked: 290 Times
^^ Get the alternator checked.
archat68 is offline   Reply With Quote
Old 4th June 2010, 07:35   #174
vigsom's Avatar
Thanked: 601 Times
Please check the voltage at the battery with the car idling without lights on - it should read 13.6-13.8 volts even at idle(the ideal value is 14-14.2V)
Check voltage again with lights on - there should be an insignificant drop(max 0.1V drop).
If the drop in voltage is more than that, it is either a weak alternator(less likely 'coz the Denso alternator is a super performer) or weak main wiring(more likely)
Old 4th June 2010, 10:58   #175
alto 12" rims cost around 650 and wagon r 13" cost around 800.
I have no idea how much you can get for your old rims.
sam_hyd is offline   Reply With Quote
Old 4th June 2010, 13:29   #176
Zen2001's Avatar
Thanked: 18 Times
In either case (battery or alternator), won't the battery light come on (very weakly on idle, if its the alternator) in the dash warning lights?
Old 4th June 2010, 16:19   #177
NOS Power's Avatar
Thanked: 55 Times
Nope it wont. The battery light is only meant for the battery and has no bearing with the alternator. Once the car starts with battery power it switches onto the power from the alternator for its electricity requirements.
So the battery light wont show up if the alternator is faulty.
One can understand that the battery is weak if the initial starter motor crank while you crank the key is slow.
You could notice this also when you try to start the engine after a long use of any electricals when the engine is off.
Old 5th June 2010, 13:01   #178
Zen2001's Avatar
Thanked: 18 Times
It happened in my car. No doubt that the battery was old, but it would still crank. The battery light would glow so dimly as to be visible only in relative darkness. Once the alternator was replaced (battery being the same), this issue was rectified.
Old 5th June 2010, 22:23   #179
Thanked: 660 Times
you cannot fit alto rims in Zen. PCD are different.
Old 6th June 2010, 08:57   #180
Sorry guys, my mistake , alto and wagon r have 100 pcd, while zen has 114.3.
I got confused as some time back when i was looking to change my zen rims, a car dealer told me that I can fit alto and wagon r rims on zen.
Buying, Owning, Driving and Maintaining a car in North America vivekiny2k The International Automotive Scene 6056 31st May 2018 19:42
Sunbeam Rapier Series 1 - Advice on Restoring and Maintaining Jehan-Sam Post-War 74 25th November 2015 08:45
Zen and the Art of Buying your First Car the_trooper Test-Drives & Initial Ownership Reports 30 21st March 2013 18:16
Cleaning and Maintaining Head Units souravbasu In-Car Entertainment 43 13th November 2009 23:21
