Old 10th November 2009, 22:25   #61
ssjr0498's Avatar
Thanked: 118 Times
@dev: Sorry to say but dang!! what the hell is that!! How on earth did that happen. I own a 2001 model zen vxi and from the past 3 yrs it is on the jacks for majority of the year (as I am in blr and the car is in kolkata, no one to drive it around) but even then, I have never ever seen such a sludge formation.
@Santosh: Dude, when was the last time you got your car serviced, look at that sludge formation.
Now that I have looked at your snaps, I am confused, what is causing this sludge formation?? Do you guys not service your cars regularly?
Btw, Santosh, that 210psi static compression is cool, I have seen the new model zens (not the estilo) having compression pressure's of 180-190psi! Also, did the mech open your head cuz without that he cant change your head gasket! Do you mean the gasket on your valve cover??
Shrey
ssjr0498 is offline   Reply With Quote
Old 10th November 2009, 22:36   #62
black12rr's Avatar
Thanked: 273 Times
@ dev , car is running fine for now ,little smoother , will add the OWS 360 petrol treatment in the next fill and check out .
What is engine stress test ?
@ssjr , vtec boy , thats the car i bought recently .I did a engine flush that should have taken care of below the piston part . I plan to remove the head cover, next week some time my self and clean up the junk .
Yes ,only the head cover was removed , the valve cover was replaced ,the head was not removed . Head gasket was wrong term .
Regarding dev's engine , he also got the car recently , hence hes also confused .
Since i have the car now it will be in top shape here onwards .
black12rr is online now   Reply With Quote
Old 10th November 2009, 23:14   #63
Jaggu's Avatar
Thanked: 7,654 Times
@black12rr: Dont bother with cleaning of head, its not really worth it (head cover you can for a feel good factor ). Instead as i mentioned earlier do an early oil change.
Old 11th November 2009, 08:46   #64
devrajman's Avatar
Thanked: 116 Times
Guys, I was shocked too when I saw the sludge!
I bought the car 2 months back. This is my first service. Previous owner showed me 2 prior service at every 5K kms at UM Cars, Airport road. Not sure why UM Cars didnt do anything!
I have the car now. I want to get it back in shape.
Any known good BKMs for removing most of it (not all of it) in next 5-10K Kms. Like additives, auto cleaning, manual cleaning, etc, etc.
Let me know your suggestions. Thanks.
devrajman is offline   Reply With Quote
Old 11th November 2009, 09:58   #65
Jaggu's Avatar
Best would be manual cleaning after stripping the head. But if your car is running alright dont bother. Do oil changes at slightly shorter period of say 3500-4000 kms and let it be.
Old 11th November 2009, 15:19   #66
nitrous's Avatar
Thanked: 283 Times
I would suggest a good synthetic oil and an oil filter change @ the 5000km and 10000km mark.
The detergents in the synthetic oil will go to work and will gradually clean out the sludge.
The Zen should need ~ 3 litres of engine oil and you can source Shell Helix Ultra @ 650 per litre.
Bosch oil filter is recommended.
Old 11th November 2009, 15:23   #67
devrajman's Avatar
Thanked: 116 Times
Currently I have put Castrol Magnetec with 3M engine oil additive. Technician told me to do this totally twice to see a difference.
How does this sludge effect engine?
Old 11th November 2009, 15:43   #68
nitrous's Avatar
Thanked: 283 Times
Instead of this "additive", the synthetic would go a long way in treating the sludge.
I reckon the synthetic oil would have costed only a few hundreds more compared to this Magnatec + 3M additive combo.
At the 5,000 km mark, move to the synthetic as I've recommended.
Old 11th November 2009, 15:46   #69
black12rr's Avatar
Thanked: 273 Times
How is Bosch oil filter compared to MGO oil filter which is 79 Rs .
How much is bosh filter for zen ?
Old 11th November 2009, 15:49   #70
devrajman's Avatar
Thanked: 116 Times
@nitrous, thanks. I will change the synthetic engine oil every 4K kms as even if kms run would be less but engine life would be more due to idling and start/stop traffic in Bangalore.
I wasnt aware of the sludge till cover was opened at MASS for tappet adjustment after oil change.
Can engine flush help? How abt seaform? Do we have this in India>
Old 11th November 2009, 17:14   #71
Jaggu's Avatar
How much has your car run so far? Reading on the odo? If its more than 70-80k kms better avoid the shift to synthetic. A semi-synthetic like Magnatec is equally good.
Old 12th November 2009, 08:58   #72
My Zen LXi has covered 32K KM so far. Some times I feel problem in shifting the gears. Do I have to change transmission oil at this stage?
AkhileshDalia is offline   Reply With Quote
Old 12th November 2009, 10:04   #73
Jaggu's Avatar
Transmission oil is changed every 20k kms, check when was it last changed, the shift issue might be a badly adjusted clutch cable.
Old 12th November 2009, 10:05   #74
devrajman's Avatar
Thanked: 116 Times
its run 81K kms on odo. is 3M good or should I use any different engine oil additive?
Also I have noticed one more thing, after gear oil change. Gear shift is a little hard and some times for reverse I hear a "kkkrrrrr...." sound. Any idea why?
Old 12th November 2009, 10:09   #75
Jaggu's Avatar
Try the additives but please note that they are not miracle cure for sludge formation, OWS is another good product. Do a search here and you will see the feedbacks.
If the oil level is correct, the sound might be more due to synchornising issues (normal since rear gear is not synchro). If you see any hesitance while engaging reverse, just slot it to first and move the car an inch and then slot back in reverse.
Buying, Owning, Driving and Maintaining a car in North America vivekiny2k The International Automotive Scene 5979 16th January 2018 03:54
Sunbeam Rapier Series 1 - Advice on Restoring and Maintaining Jehan-Sam Post-War 74 25th November 2015 08:45
Zen and the Art of Buying your First Car the_trooper Test-Drives & Initial Ownership Reports 30 21st March 2013 18:16
Cleaning and Maintaining Head Units souravbasu In-Car Entertainment 43 13th November 2009 23:21
