Old 14th December 2009, 19:14   #91
ElantraGT's Avatar
Cool
Originally Posted by recshenoy View Post
Guys,
what is the GC of a stock carb zen? I have been driving one for a while without knowing GC
AFAIK Its 165mm. I will recheck it once again in the user manual when i get home.
ElantraGT is offline   Reply With Quote
Old 15th December 2009, 19:44   #92
recshenoy's Avatar
Thanked: 104 Times
Question Zen manual
Thanks ElantraGT.
Any one here has soft copy of Carb zen manual. I dont have one with me.
If some one has kindly share
recshenoy is offline   Reply With Quote
Old 15th December 2009, 20:59   #93
black12rr's Avatar
Thanked: 273 Times
Zen manual Zen manual
black12rr is offline   Reply With Quote
Old 2nd January 2010, 18:16   #94
Default right strut shot
My 2004 zen right strut is gone. According to Mass I can use the car for another 10k and then change the struts. But, when I inquired from an after market garage, they said, I should change it immediately.
Current Odo reading is 34k. Please suggest, whether I need to change it immediately or not.
How much is it going to cost me ?
sam_hyd is offline   Reply With Quote
Old 2nd January 2010, 22:41   #95
sumeethaldankar's Avatar
Thanked: 1,133 Times
Check out this link.Not sure if the price list is updated but it might give you a idea.
Maruti Zen Maintenance
Also take a look at post 39 of this same thread.
http://www.team-bhp.com/forum/1562278-post39.html
sumeethaldankar is online now   Reply With Quote
Old 14th January 2010, 09:42   #96
Aston.Martin's Avatar
Thanked: 33 Times
Default Noise from the Gear Box
I have a problem here and I would really appreciate your inputs. While accelerating in neutral there is a loud Krrrrrr.. noise from
the gear box which can be heard from the cabin itself. Last time when I left the car for service I could hear the same noise when
the bonnet is open (only while accelerating in neutral) and it was not so loud then, when I asked the service tech he told me there
is nothing to worry, its the 5th gear noise and its common. Any idea on what it is ?
Aston.Martin is offline   Reply With Quote
Old 14th January 2010, 19:47   #97
vigsom's Avatar
Thanked: 601 Times
Does the noise disappear when you press the clutch pedal?
Old 14th January 2010, 20:00   #98
HIGHNOON's Avatar
Thanked: 56 Times
You could get a krrrr noise due to clutch bearing failure.
Or it could be the play in the overdrive , but that noise is usually a frfrfrfrfr type kind of muted and directly roportional to speed and as he siad its quite common. But should it be there when in neutral.... ?
HIGHNOON is offline   Reply With Quote
Old 14th January 2010, 22:14   #99
Thanked: 33 Times
Valid point, I never tried that...Now I did and there is no noise when I press the clutch...Is it because of the clutch bearing ? Is it fatal ? How do I fix it ? Any idea about the cost ?....too many questions, sorry, kindly bear with me...
Old 15th January 2010, 15:22   #100
Jaggu's Avatar
Thanked: 8,567 Times
You will need to overhaul clutch, seems like a failed clutch release bearing. While replacing check all the other parts of clutch assembly if the clutch has done more than 20k kms and replace if necessary. Dont go by another 5k kms life, this is to avoid a repeat job in the near future.
Complete clutch overhaul comes to 5-6k, if only bearing it should be within 1.5k. Am not very sure about the current prices
Old 15th January 2010, 15:37   #101
dar3dev|l's Avatar
Thanked: 88 Times
many thanx for the manual, it indeed is helpful for zen owner. Helped a lot of understand few points i never realised or noticed
The best part of the doc is it covers both carb & mpfi version of it.
dar3dev|l is online now   Reply With Quote
Old 15th January 2010, 23:35   #102
vigsom's Avatar
Thanked: 601 Times
it is normal to hear a slight noise from the gear box when the clutch pedal is not depressed;-this noise is the noise of the lay gear n shaft. When the clutch pedal is depressed,the noise disappears
When the clutch pedal is depressed and noise increases,it is a sign of clutch release bearing wear.
In your case,based on what you have mentioned,the release bearing is OK.
I can say with 50% confidence that the krrrr noise you're hearing is also quite normal(50% because I am not around to check)
Old 16th January 2010, 09:57   #103
Thanked: 33 Times
Thanks @ Jaggu,
@ vigsom, the noise is getting louder day by day, that is worrying me. I think I will have to take her to a mech.
Old 16th January 2010, 15:47   #104
Hashim's Avatar
Thanked: 32 Times
I am hearing this "khir khir" type noise in my M1000 too from quite sometime and its coming from clutch housing. After reading this thread today I check after pressing the clutch pedal and yes the sound does disappear when pressed and comes again when released. This noise raise as we increase engine RPM.
I recorded the sound and want engine gurus here to listen and tell me what is gone bad, is it clutch bearing? then I might give a good to that mechanic who said "clutch bearing bilkul theek hai mene apke 500 rupay bacha liye" while changing clutch few months back.
Hashim is offline   Reply With Quote
Old 16th January 2010, 18:30   #105
HIGHNOON's Avatar
Thanked: 56 Times
It makes sense to change the entire kit
1) clutch release cable
2) clutch release bearing
3) clutch plate
4) pressure plate.
changing the later 3 means an entire job, full labour cost . the cable can be changed alagse.
Buying, Owning, Driving and Maintaining a car in North America vivekiny2k The International Automotive Scene 6056 31st May 2018 19:42
Sunbeam Rapier Series 1 - Advice on Restoring and Maintaining Jehan-Sam Post-War 74 25th November 2015 08:45
Zen and the Art of Buying your First Car the_trooper Test-Drives & Initial Ownership Reports 30 21st March 2013 18:16
Cleaning and Maintaining Head Units souravbasu In-Car Entertainment 43 13th November 2009 23:21
