Old 29th October 2009, 14:20   #1
Red face Punto -Turning Steering Issue
Hi All,
I have been an avid reader on the forums and the hours of research on the forum has helped me on finalizing on my Punto 1.4 EP
So thanks to all the tbhpians.
I had a niggling query on the car, which i have not been able to get cleared so far from the dealer. Wanted to check with other punto owners on the same.
"The steering when turned extreme left or extreme right (i.e. when it cant be turned further), there is a slight hiss. this goes away if i give the steering a bit of slack. Is this a problem with the steering or its the way punto letting you know you are turning too much?
I have a swift lxi which doesnt give any such feedback when turned either ways.
Any thoughts would be appreciated.
paritosh2k is offline   Reply With Quote
Old 29th October 2009, 15:05   #2
somebodystopme's Avatar
Thanked: 17 Times
I didnt notice any such thing during my test drive I turned the steering complete twice... No hiss nothing...even if it is it must be a very very low hiss. Which normally you are notable to hear...
somebodystopme is offline   Reply With Quote
Old 29th October 2009, 15:08   #3
ImmortalZ's Avatar
Thanked: 312 Times
The hiss is the power steering releasing pressure through a bypass valve which would otherwise blow up the rack. Don't worry about it. However, it is not advisable to keep pressure on the steering at the limit for more than 5 seconds at a time because it is the point where there is maximum forces acting in the system.
The Swift doesn't have this noise because it has EPS.
Old 29th October 2009, 15:09   #4
rudrah's Avatar
Thanked: 29 Times
Paritosh, that noise should be the steering pump noise. Its there in my Palio Stile 1.6 too! I don't think you need to worry about that. Its normal.
Also it is advisable not to keep the steering to extreme left/right for long time.
rudrah is offline   Reply With Quote
Old 29th October 2009, 15:12   #5
Thanked: 34 Times
The hiss is perfectly OK. Do not worry about that. Just make sure you do not hold the steering in the same position for more than, say about 15 sec.
deepakhon is offline   Reply With Quote
Old 29th October 2009, 15:12   #6
pramodkumar's Avatar
Thanked: 947 Times
I get a whine in my lancer, are there any issues with the pump, the A S S said it could be they are not sure
Pramod
Old 29th October 2009, 15:16   #7
ImmortalZ's Avatar
Thanked: 312 Times
Is the whine present all the time? In that case, it is something that needs to be investigated. If the noise is present only when the steering is at the extremities, it is normal. But if it's getting louder, then once again, the system needs to be inspected.
Old 29th October 2009, 16:06   #8
Thumbs up Thats a relief
Thanks ImmortalZ for the reassuaring reply.
never drove a Hydraulic Power Steering vehicle hence felt like a bit weird.
5 Seconds: A gut feel clock forces to get rid of the steering as soon as i hear it. Have to do that only when trying to squeeze in a parking spot..
Paritosh
Old 29th October 2009, 16:17   #9
ms001's Avatar
Thanked: 63 Times
Paritosh
I have punto active mjd and the behavior is the same as in yours, there a sound like liquid transfer.
ms001 is offline   Reply With Quote
Old 29th October 2009, 17:43   #10
neoonwheels's Avatar
Thanked: 630 Times
Yes it is because of HPS. My Palio also shows this behavior when steering is locked to extreme. This is normal. As Immortalz said, do not keep it locked at the extreme position.
Mods: As this is not an issue, please mark this thread as "Not issue" as this may create an impression that the car is having steering wheel issue. Not everybody reads the whole thread.
neoonwheels is online now   Reply With Quote
Old 29th October 2009, 22:46   #11
Thanked: 152 Times
This is not a issue at all . It is totally normal for Hydraulic Power Steering Systems such as in Santro , Punto etc.
Trust_In_Thrust is offline   Reply With Quote
Old 29th October 2009, 22:51   #12
Thanked: 212 Times
Spot on. I find it in my Lancer as well.
lancer_rit is offline   Reply With Quote
Old 29th October 2009, 22:54   #13
Mods:
Agree with the comments. Its is Not an Issue but "std behaviour". Can you pl. change the title and close the thread. Thanks
Old 30th November 2009, 11:34   #14
Thanked: 15 Times
Here is my take.
So far I have crossed 9K kms I never had an issues with steering until, last week. during extreme turn (even in 40kmph) I get a beep sound warning with hand brake symbol on. The moment the steering is straight again the hand brake symbol turns off. I was in Chennai, I easily face this all the time when I take a curvy turn in Gundy flyover Chennai. (Tambram to Anna Salai, people in Chennai can get a better idea on what road I am talking)
I spoke to my service advice on phone he said is just a precaution warning you come to Bangalore we will do a routine check. But last 2 days when take a extreme turn, I get a beep sound, hand brake symbol on, and I get a message on dashboard, brake fluid level insufficient do not proceed. on my return I tried to check the brake fluid in SHELL and found it is in normal level (above min).
Planning take for check up, top-up etc this week.
Chuchan is offline   Reply With Quote
Old 30th November 2009, 12:01   #15
leadf00t's Avatar
Thanked: 12 Times
yes i also geta whine in my lancer at each steeering lock .
guess its normals. hush i too was a bit worried when parking at tight spaces.
Pramod
leadf00t is offline   Reply With Quote
MM550: Issue with steering precision & turning radius ananthkamath 4x4 Technical 16 31st December 2015 16:14
Ford Ikon 1.6 issue - Burning Smell After turning on AC Sugeeta Technical Stuff 12 10th February 2015 23:56
Sound from front wheels while turning the steering at standstill narasimha raju Technical Stuff 17 12th December 2014 00:55
A sound while turning the steering wheel. InternetUser Technical Stuff 8 19th December 2012 09:21
