Old 31st October 2009, 08:37   #1
iamswift's Avatar
Thanked: 65 Times
Question Silencer modification for monsoon
Hi guys,
During monsoon, it is often a nuisance that sometimes rain water enters silencer when riding through water seeped roads (of atleast Chennai and Mumbai - Not sure about Pune) and thereby killing the engine.
Is it possible to attach a vertical air-tight pipe to the silencer which prevents water from entering? After monsoon is gone, this extra attachment can be removed.
Has someone tried this already? What problem might occur if this extra pipe is added?
Performance? Startup issues? Other technical problems?
iamswift is offline   Reply With Quote
Old 1st November 2009, 15:09   #2
Thanked: 103,414 Times
Man, you are talking on the lines of us Jeepers, when we are getting custom-made air intakes installed.
Probably a better idea to not ride through water-logged roads in the first place?
I don't think its a good idea. Will make the exhaust more restrictive (interrupting the smooth flow of exhaust gases) and could end up burning your pillion riders leg!
Old 1st November 2009, 16:06   #3
Thanked: 1,046 Times
Just to be clear, are you looking to install this device in a car or a bike? I know you've mentioned riding but your user details seem suggest using a 4 wheeler.
Axe77 is online now   Reply With Quote
Old 2nd November 2009, 13:27   #4
iamswift's Avatar
Thanked: 65 Times
Hi GTO, Sometimes, there won't be any alternate routes available. In Chennai it happens all the time. At those times, I had to rev the engine so that water does not enter silencer. Sometimes the vehicles moving before would slow down / stop for something and I too have to stop - bit difficult you see...
Oops - that will be bad. Had this been a situation in China, I'm sure they would have come up with a solution.
My bad. It should be "driving" and not "riding".
Though the same problem is applicable to two-wheelers too.
GoldStar Silencer goswami.j Motorbikes 320 7th February 2016 20:25
Silencer Modification for Electra 4S thimappa Motorbikes 13 10th May 2012 14:52
Decarbonizing your diesel car silencer at home tsk1979 Technical Stuff 16 30th July 2006 10:53
Baleno silencer touches filcord Technical Stuff 12 8th December 2005 22:20
MATIZ - Silencer noise SCH Technical Stuff 7 23rd March 2005 00:32
