Old 3rd November 2009, 02:20   #1
Default Help for Tata 207
hi
I have a tata 207 of 1994 with a gearbox failure
so can you tell me which gearbox is compatible with the tata 207 (from an other car)
engine type 483 dl
akremj is offline   Reply With Quote
Old 3rd November 2009, 11:03   #2
condor's Avatar
Thanked: 4,898 Times
@Akrem : Checked with my service advisor. You will need the G-16 gear box.
Old 3rd November 2009, 12:21   #3
thanks
but i am tunisian and we dont have many tata model on our roads
so please can you tell mein witch other car can i find a G-16 or G-76 gear box
Old 3rd November 2009, 12:37   #4
4x4addict's Avatar
Thanked: 2,668 Times
It is based on an old Mercedes design. So try to find a gearbox from any of the older Mercedes diesel cars.
4x4addict is offline   Reply With Quote
Old 3rd November 2009, 12:44   #5
condor's Avatar
@Akrem, can you tell us which other Tata cars are available in Tunisia / other areas that are within your reach.
Old 4th November 2009, 02:11   #6
only tata telcoline and 207 mobile
Old 4th November 2009, 23:10   #7
Thanked: 660 Times
I just saw that you live Out of India! other wise old Estate gear box may also be compatible which is dirt cheap here in India.
What is the nature of GB now, what do you exactly mean by failure. As each parts of gearbox is serviceable/replaceble instead of changing whole GB.
Unless the whole bell housing is cracked of something.
Old 5th November 2009, 01:36   #8
please on a tata 207 where can i find the color code
Old 5th November 2009, 01:48   #9
Thanked: 53 Times
Originally Posted by akremj View Post
hi
engine type 483 dl
What is the problem with the gearbox?
The engine number suggest it's the same engine used in the TL,Safari,etc in short the Turbocharged 2.0L engine. So the TL gear box will fit.
dinar is offline   Reply With Quote
Old 5th November 2009, 02:11   #10
Thanked: 660 Times
^^^ they never had turbocharged engine then.
Old 7th November 2009, 20:22   #11
yes the 1994 tata's has never turbocharged engine
Old 7th November 2009, 21:47   #12
nitrous's Avatar
Thanked: 285 Times
Tata Sumo or Tata Safari's gearbox should fit.
But, the ratios would differ.
Old 7th November 2009, 23:16   #13
condor's Avatar
@Nitrous, Sumo / Safari has the G-76 g/b. The exact model Akrem needs is the G-16. Possibly salvaged from another 207 / TataMobile / Estate ?
Old 8th November 2009, 01:40   #14
thank's for all of you but in tunisia we don't have sumo or estate i hope thatyou tell me if the gear box of an other Car manufacturer fit my tata 207.
Old 8th November 2009, 08:58   #15
Thanked: 53 Times
There was a TOYOTA Hilux converted [in belgaum,kanataka ] to run tha TATA 483 Turbo engine as the original engine had it's block cracked, do not know if the gear box was changed, but the 4wd was retained so I think the originla drive line was in the vehicle, You can try that gear box.[it will need an adapter plate].
Sorry did not see the Model year. it's the original 2.0L engine
Last edited by Dippy : 8th November 2009 at 10:13. Reason: Back to back posts. Please use the edit function if reposting within 20 minutes of your earlier post. Thanks.
The good old Tata 207. PICS from around India BunnyPunia Commercial Vehicles 18 5th June 2018 07:12
100 Kms in chennai with TATA 207 joshguy Commercial Vehicles 3 15th September 2010 17:46
Modifications for TATA 207 Abhi2902 Modifications & Accessories 11 21st October 2009 11:46
Tata 207 VS Mahindra Maxx rahul_intlad Commercial Vehicles 18 2nd May 2007 12:22
tata 207 DI BunnyPunia Long-Term Ownership Reviews 0 29th October 2006 00:54
