Old 3rd November 2009, 10:26   #1
Default Wobbling and Losing Pickup after a accident-indica vista
Hi all,
My Indica vista recently met with a small accident.I hit a santro car that jumped the signal and suddenly came in front of me.
The damage appears to be minimal(Damage to bumper,which will be replaced and slight bending of bonnet).However I saw that immediately after accident,the car's pickup has reduced and car is wobbling badly whenever I change gears from second to third ,third to fourth ,or whenever I increase/decrease the acceleartor.
I am giving it for service tommorow and the service guys estimate is that engine has moved slightly and that is the reason for this issue.
Please do let me know if you have faced any such issues or any solutions for this issues.
Hdi.
hdi_pro is offline   Reply With Quote
Old 3rd November 2009, 10:29   #2
tsk1979's Avatar
Thanked: 16,422 Times
Check for two things
1. Diesel leakage from the pipe(this sits in front of the engine)
2. Engine mounts
Do you also get idle surging?
Old 3rd November 2009, 10:35   #3
2. Engine mounts
Thanks tsk1979,
I will check the diesel leakage from the Pipe.However I am not sure what is idle surging.
What is idle surging.
hdi.
Old 3rd November 2009, 10:40   #4
tsk1979's Avatar
When your engine is at idle speed(accelerator not pressed), it should idle at one speed. If speed keeps increasing and decreasing on its own, its called erratic idle. When idling engine speed rises in "surges" its called surging.
Old 3rd November 2009, 11:25   #5
Jaggu's Avatar
Thanked: 8,696 Times
Check engine alignment and the wheels, if they are bent by any chance.
Old 3rd November 2009, 14:41   #6
McLaren Rulez's Avatar
Thanked: 591 Times
Wheel alignment and/or balancing may be required to solve the wobbling. Do get it fixed soon and don't use the car until then because it could be dangerous.
McLaren Rulez is online now   Reply With Quote
Old 3rd November 2009, 22:07   #7
Just got the quote from the Service A.S.S
New Bumper -4500
Insurance charges -500
Total Cost to me(Insurance bajaj allianz)
50% of bumper-2250
Insurance charges-500
What do you think.Am I being taken for ride for the bumper cost.
Hari.
Old 6th November 2009, 10:05   #8
Came from the workshop right now and the Service advisor has told me that the intercoller is leaking and that is the reason for the sluggish pickup and wobbling.I looked at the intercooler and I saw some leakage
Since this is a plastic mixed part I have to pay 50% of the cost(Rs 4531)
So here are my questions
a) How important is the intercooler(Goggle says something about the air to the engine and its important for turbo engines) and what is relation to pickup
b)Will it ok if we just plug the leak and carry on (rather than chaning the intercooler)
Hdi.
Old 6th November 2009, 12:19   #9
teknophobia's Avatar
Thanked: 22 Times
The intercooler is a vital part of the intake system of your engine, please don't try to skimp on it.
teknophobia is offline   Reply With Quote
Old 6th November 2009, 12:59   #10
extreme_torque's Avatar
Thanked: 1,489 Times
I wanted to say intercooler but you know already. See if its only leaking or the tube has displaced itself due to the shunt. My cousin's Indica Vista hit a dog on the expressway and he faced the same sluggish issue and in this case the intercooler tube was diplaced.
extreme_torque is offline   Reply With Quote
Old 6th November 2009, 15:27   #11
harry10's Avatar
Thanked: 617 Times
New Bumper -4500
50% of bumper-2250
Hari.
Guess you had taken insurance claim already and if you haven't then will suggest not to take it as the cost is not high and your NCB will get effected.
harry10 is online now   Reply With Quote
Old 6th November 2009, 18:10   #12
Thanks for the replay teknophobia.
I will try to replace it .
-hdi
Old 6th November 2009, 18:12   #13
greenhorn's Avatar
Thanked: 1,519 Times
to give you an idea, its as important as the radiator
2007 Indica Xeta: Engine losing power all of a sudden and regaining power after mins mohandas Technical Stuff 17 3rd May 2016 07:37
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
ICE for Vista Limited Edition without losing boot space koushikvenkat In-Car Entertainment 12 15th January 2011 23:23
Engine losing power in Vista MJD akhilesh51 Technical Stuff 41 28th December 2009 12:07
Indica Vista Official Brochure! EDIT: Vista Now Launched sidindica The Indian Car Scene 233 24th August 2008 18:49
