Old 8th November 2009, 13:55   #1
Unhappy Help:Hyundai Getz 1.3 stalled midway..
Dear Members,
I own a Hyundai getz 1.3 2005 which has done 46960 kms. It is a second owner vehicle which i had purchased from a used car dealer in february. Yesterday a horrific incident happened while i was driving through heavy rains. The car just went dead midway through traffic!!..I had to literally push the car with the help of crowd around and park it towards the side of the road. Then itried to restart the engine second time..it wouldnt start.All i could hear was a whizzing sound from the starter. The again tried the third time.. but i was again getting the same sound. Stranded midway i called up DSC Hyundai hotline and they arrived in half an hour in a mobile service car. The machanic inspected the car and after going through he informed me that the timing belt has snapped and there are 75% chances valves have bent. How much of a damage can that be??Can it be repaired or do i have to go for a engine replacement..Itz hard for me to swallow the costs associated...so r there any other alternatives here in chennai??Itz funny coz i had recently seviced my vehicle at 46000 and replaced all necessary parts.. but the mechanic there never informed about timing belt replacement. Strangely enough lukin backwards 2-3 days i started hearing funny noises from the engine at idle..i had my doubts..but i took it for granted!!I also hav a doubt bout my vehicles original milaege coz timing belts usually hav to be replaced only at 60-75k kms,and also accordind to hyundai database it has run 89k.
So dear members is there any specialists i can consult regarding this problem in chennai??
What are the costs i m looking at??
Raghav are you hearing me??
Your help will be truly appreciated...thanks
Note from the Team-BHP Support Staff : SMS / Slang language is not the preferred mode of communication on Team-BHP. We would much appreciate if you type your post out in clear and concise english for the benefit of other community members.
hunkyfydex is offline   Reply With Quote
Old 8th November 2009, 14:48   #2
I hav just now recieved a call from the service advisor...he has given me a cost estimate of 25k!!!!!!!!!!!!
Valves, Timing Belt, A/c belt, Inlet valve, exhaust valve, haed gasket, a/c, alternator, power steering belt, camshaft, manifold, latch assembly hav to be replaced...
Car is currently in DSC hyundai saidapet chennai..
Anyone help..please tell what should i do??
Old 8th November 2009, 14:58   #3
Thanked: 54 Times
First thing would be to check the status of the engine What are the parts that ned to be changed . If the engine does work after a change of timing belt. I would be glad for you .
since you have bought a 2nd hand car ,the kms might have been tripped . If the damage is extensive like replacing the head ,connecting rods , pistons etc get your self a totalled engine from a fairly new car . It is cheaper that way .
PM me if you need a mechanic who isnt expensive .
Last edited by Dippy : 10th November 2009 at 09:19. Reason: Post edited. Please use proper punctuation to type out your post. Avoid typing like... this...
Old 8th November 2009, 15:31   #4
maglev's Avatar
Thanked: 88 Times
My Accent's timing belt snapped at 58000kms.
There is a very very high chance that the Engine Valves must be bent, the entire repair should cost you around 15-25K (depending on the number of parts to be changed) if you get it done at an authorized service station.
And yes the used car dealer did take you for a ride. In most probability the car has done above 1 lac kms.
maglev is offline   Reply With Quote
Old 8th November 2009, 22:57   #5
techn0l0gist's Avatar
Thanked: 27 Times
I'm not sure about the camshaft but manifold change sounds weird ! what latch assembly ?
techn0l0gist is offline   Reply With Quote
Old 9th November 2009, 11:13   #6
aaggoswami's Avatar
Thanked: 1,426 Times
So its inference engine. Now that its damaged, there is nothing you can do. Only option is to repair the engine.
If the crank is not damaged, its good. Generally in these cases the repairs are expensive.
What was the odometer reading when you bought the car ? You have stated once its 46K kms you have replaced some parts and next you mention its 89K, so IMO, you are cheated by the dealer.
I am not sure but its better if you visit the dealer personally and look at damaged components. How much did you try to crank the engine. Counting its more than 10 seconds, chances are that more than one piston and more than 3 vavles will be damaged, in worst case all 12 valve will need replacement.
aaggoswami is offline   Reply With Quote
Old 9th November 2009, 11:29   #7
Shan2nu's Avatar
Thanked: 87 Times
I dont understand why manufacturers still make interference engines and then run it with a belt, which has a higher chance of snapping. Its as if they do it on purpose so that they can loot the customer whenever the belt breaks.
Shan2nu
Old 9th November 2009, 13:37   #8
Guys....The workshop is asking me 5k just 2 dislodge the engine!!
Is there any other way to find out damaged internal components??
plz help!!
Old 9th November 2009, 15:13   #9
akash_m's Avatar
Thanked: 88 Times
Its obvious from your post that the odometer has been tampered before you purchased this car. The timing belt is usually recommended to be changes at 80k - 1 lac km in every car.
If it is broken at 49k kms as in your case, that means the actual odo reading of your car must be at least 1 lac+ kms.
akash_m is offline   Reply With Quote
Old 9th November 2009, 15:18   #10
Gilead's Avatar
Thanked: 20 Times
My 800's timing belt snapped at 35K. But no other damage. It cost me 200 bucks for the belt and labor and 900 bucks for towing.
Gilead is offline   Reply With Quote
Old 9th November 2009, 15:29   #11
Gansan's Avatar
Thanked: 875 Times
Shan2nu
Well, you learn something every day! First time I heard of this type of engine. Hope the Alto does not have this type.
Old 9th November 2009, 16:09   #12
Mr_Bean's Avatar
Thanked: 130 Times
Sad to hear this, get the vehicle checked again by a trusted and experience mechanic.
Can you mention the details of the dealer from whom the car was purchased.
Mr_Bean is offline   Reply With Quote
Old 9th November 2009, 23:07   #13
para_7k's Avatar
Thanked: 63 Times
I strongly suggest you take a second opinion. Send me a PM if you want to check with an inexpensive mechanic.
para_7k is offline   Reply With Quote
Old 9th November 2009, 23:08   #14
I tried cranking it 2-3 times, but not more than 5 seconds..however vehicle is at the workshop and there is lot of probaility that it has been cranked by people there leadin to a lot of internal damage..
Old 10th November 2009, 00:58   #15
pranavt's Avatar
Thanked: 272 Times
You have mentioned inlet valves, exhaust valves, and "valves" seperately. Are you confused or have they mentioned this multiple times? Also, why the intake/exhaust manifold, alternator, a/c? What latch assembly?
The usual rebuild job involves changing crankshaft, rods, pistons (+rings), valves, camshafts and timing belt depending on what's broken, and finally a new head gasket. Since only your valves are damaged, all that's needed is new valves, camshaft/s, head gasket and timing belt and other miscellaneous stuff. Pay more attention to the estimate and make them explain why they are replacing each part, and ask them to give you the old parts when you get the car back.
Year 2000 Maruti Zen LX stalled! abhipuru16 Technical Stuff 11 31st March 2010 14:28
Bangalore to Mandegadda (Midway of Thirthahalli - Shimoga) Sowmya Travelogues 10 29th September 2009 12:39
Help! Baleno AC not working after car stalled in water. aaggoswami Technical Stuff 19 20th September 2009 22:56
Mumbai-Goa:midway halt reqd? v_sukumar Route / Travel Queries 17 30th October 2008 20:14
Sat'day or Sunday for The Bangy-Chennai Midway meet? nitrous The Team-BHP Meet Section 136 13th July 2007 23:56
