Old 8th November 2009, 18:06   #1
COUGAR's Avatar
Thanked: 86 Times
Default OBD-II scanner for Gypsy
I am looking for an OBD-II scanner to read engine and other parameters for display on a carputer to be mounted on a Gypsy MPFI 2007 model. I was told i need to look for a 9141-x compliant scanner.
Checking on the Ir*de site, i came across 2 USB models with the said support: ELM323USB and ELM327USB.
Would either of these work properly in the Gypsy? Is it a standard plug-andplay kind of operation? I saw this being done on a Santro where it was pretty much connect and go. Will it be just as easy for the Gypsy? My mech tells me it wont work because Maruti puts some kind of code to encrypt/lock out external readers. How can that be?
Anything else I should keep in mind?
COUGAR is offline   Reply With Quote
Old 8th November 2009, 18:31   #2
memo45_m's Avatar
Thanked: 61 Times
Well the only scanner that I know that works is the Tech II that Maruti dealers use to work on the cars, other generic scanners usually don't do the job as there is no rule in India which says any scanners is to read the majority of P-codes that an engine control module(ecm)/ body control module(bcm) will put out if it detects any changes. But others who have tried can do tell there experience, if I have any problem I just go to RNS Motors, Yeshantpur, or for just P-codes there is a procedure to get it to flash on the LCD in the ODO,(Works with the Swift,SX4,A-star,Ritz,GV)
memo45_m is offline   Reply With Quote
Old 8th November 2009, 22:37   #3
DRC
DRC's Avatar
Thanked: 48 Times
memo, could you please tell us how to flash p codes on Odo?
DRC is offline   Reply With Quote
Old 9th November 2009, 12:33   #4
memo45_m's Avatar
Thanked: 61 Times
Sir you ned to tell me for which model so I could PM you the same, there is a small procedure difference from model to model.
Old 9th November 2009, 12:55   #5
memo45_m's Avatar
Thanked: 61 Times
Old 21st December 2009, 20:03   #6
COUGAR's Avatar
Thanked: 86 Times
Bumping up this thread with an update.
Yesterday we tried to use an OBDII scanner with my Gypsy and the scanner wouldnt proceed beyond the "Connecting" message on the ScanGauge display.
Looks like my carputer wont be able to read the engine parameters after all?
any help would be appreciated.
$50 only! Launch X431 OBD-II Scanner with Maruti & Hyundai software a4anurag Technical Stuff 59 23rd January 2017 08:41
OBD-2 Handheld Scanner NPD: Survey subache Shifting gears 3 16th November 2009 14:31
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
High-end imported bikes under Customs scanner downsouth Superbikes & Imports 4 2nd December 2008 22:48
