| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | I've been in the market for a used hatchback and have been coming across a lot of LPG kitted cars. I don't want anything to do with the LPG kit. I'd like to know if anyone knows the longterm effects of LPG on an engine? What I mean is, will it be okay to buy a car that has been running on LPG for a few years previously and now run on petrol? Because thats what I intend to do - remove the kit and run the car only in petrol. Or am I better off looking for a car without the kit which is getting extremely difficult by the way. Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari |
| | #3 (permalink) |
| Senior - BHPian | I have used LPG in my cars. But if you are looking to use only in petrol mode, why bother buying a car with LPG ? One reason you could avoid a LPG car is it's mileage. It could have been used a lot.
__________________ "Keep your friends close, Keep your enemies closer" |
| | #4 (permalink) |
| Senior - BHPian | The problem is that all I'm finding are LPG cars. I don't it should be a problem to run the car in petrol only after a few years of running on LPG, but need to make sure. So if someone has had experience with something like this, it would be great. Drifter
| | #5 (permalink) |
| BHPian Join Date: Oct 2008 Location: Bangalore<-->Madras
| Cars that have run on LPG for considerable mileage will have some waxing problem in the carb and some gumming up of the injectors, if fuel injected. But this is more prevalent in carb models than in newer MPFI's. If you're buying a MPFI or equivalent, it's quite enough if you clean the injectors and the fuel system with some good chemical additive like OWS. I can think of no other long term side effects of LPG. |
| | #6 (permalink) |
| BHPian Join Date: Apr 2009 Location: Bangalore
| I have some long term experience with the older generation of LPG powered cars (carb ones) - A Padmini S1 and a M800. Both if these were run on petrol for about 20K km and then were fitted with gas kits. Both the engines lasted about 1.1 L km of city driving before needing overhauls (due to excessive oil combustion) which is at par with what would have been expected from them if run on petrol. Can't comment on the ECU and injectors part of it though. I've seen several bad LPG installs with the wiring being in tatters and some other LPG installs where the check engine light used to stay on in LPG mode. A proper LPG install without crimped and cut wires should be the thing to look for to ensure trouble free performance after removing the kit.
__________________ The man who smiles when things go wrong has thought of someone to blame it on. Last edited by CrackedHead : 9th November 2009 at 20:18. |
| | #7 (permalink) |
| Senior - BHPian | Thanks for the insight guys. So cars that have been running lets say about 20000kms/2 years should require no more than a proper tuneup, injector cleaning and engine decarb maybe? Drifter
| | #8 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: mumbai
| Cars if have lpg kits installed and maintained properly will give you no trouble. i have run mpfi for 50k till now and have not yet needed any cleaning of injectors or throttle body. In the whole period i have personally only cleaned air filter, replaced the spark plugs and cleaned the intake area upto the butterfly valve few times. |
| | #10 (permalink) |
| BHPian Join Date: May 2009 Location: Chennai
| My colleague has a used Esteem to which he has fitted a Lovato kit. He has been driving it for quite a few years without any issues, with a usage of around 500 KM per month. But on the other hand, I spoke to a few of cabbies whenever I travelled by call taxis. These were Omnis with factory fitted gas kits. They all opined the engine life goes down by about 30% as compared to cars that run on petrol, due to the higher operating temperature.
__________________ Splendor Feb'2000 - 79200 KM. Alto LXi June 2009 - 2650 KM. What do you mean,my bike is old? It has not even done 100,000 KM! |
| | #11 (permalink) |
| Double post, please remove.
__________________ Splendor Feb'2000 - 79200 KM. Alto LXi June 2009 - 2650 KM. What do you mean,my bike is old? It has not even done 100,000 KM! Last edited by Gansan : 10th November 2009 at 12:22. |
« What happens to the engine oil when the Oil cap and/or dipstick is opened and engine?
Help:Hyundai Getz 1.3 stalled midway.. »
| Thread Tools | |
Similar Threads | ||||
| LPG car for my parents (Old Alto or new 800 LPG) | jits_1998 | Hatchbacks | 7 | 9th October 2009 12:19 |
| Santro GL LPG or Spark LS LPG | arunjeetsingh | Hatchbacks | 12 | 22nd September 2009 12:13 |
| issues with fiat | kapilsharma80 | Indian Car Dealerships | 12 | 12th August 2009 17:06 |
| Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode | shineshine | Technical Stuff | 9 | 10th May 2009 05:52 |
| Wagon-R: VXi+LPG OR LXi+Upgrades+LPG? EDIT: Now booked LXi | sohu9 | Hatchbacks | 14 | 16th January 2007 13:37 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
