Old 3rd May 2006, 01:59   #16
v.tec's Avatar
Thanked: 16 Times
Originally Posted by v.tec
well i was searching for brake oil change..but could find this the closest topic..
anyway..i wanted to know when should one get the brake oil changed/filled? ive no clue about what it is though..but yeah in a new car i heard that one should get the brake oil changed at 5k or 10k? aint sure about that either ..please help
hey i was asking about this ...the rest are one year old posts lol
v.tec is offline   Reply With Quote
Old 3rd May 2006, 02:02   #17
Deeps's Avatar
Thanked: 67 Times
As far as i know, the oil does not need to be changed but only topped up. But just for my own satisfaction, i'd probably get the brake system flushed and refilled after certain time intervals.
Deeps is offline   Reply With Quote
Old 3rd May 2006, 09:38   #18
Rehaan's Avatar
Thanked: 22,568 Times
Dust, dirt, air and moisture.
Your brake fluid's worst enemies.
(Might i take this opportune moment to add that its brake fluild and not brake oil, just FYI)
So as i was saying, over time, any/all of the above get into your fluid, and its best to bleed out the system and put in some new brake fluid, rather than just topping up all the time.
cya
R
Old 3rd May 2006, 10:46   #19
tsk1979's Avatar
Thanked: 15,640 Times
A moderately hard jab on the brakes should provide adequate braking force. If you need to stand on the brakes for even minor emergency braking, its time to check out your brake system.
Most pads gon bad give a screechy noise, but most brake faliures are not due to pads. Pads go gradually and you notice you need to apply more and more force.
Its the master cylinder which is the main culprit. Most cars have master cylinders which have rubber seals. Now rubber is a material which can get damaged with heat, water etc., etc., So you spring a leak. Many people dont give heed to that red brake warning light which doubles up as a hand brake light too. The end result. You slam the brakes and nothing happens.
In many cars the brake system warning light is not very reliable, so the moment you feel your pedal getting "spongy" go for a check. It could be a simple case of air in the system or a more serious problem
Old 3rd May 2006, 12:37   #20
Thanked: 12 Times
Default Should I replace brake pads?
Hi guys,
I'm slightly confused. I drive a WagonR and have done more than 85K on it. Have not changed the brake pads or the clutch pads as well. The maruti dealers (atleast a couple in Blr) have told me that the brake pads will last another 10K on the odometer.
Now I have the following questions:
1. There is no squealing, brake fell being soft etc etc. Should i still replace the pads.
2. What does Maruti recommends for brake pad replacement period.
What do you guys think?
lsjey
lsjey is offline   Reply With Quote
Old 3rd May 2006, 12:48   #21
dhirajs's Avatar
Thanked: 11 Times
Ive changed the brake pads thrice on my ohc,it has clocked 105000kms.A pairs costs Rs.3600(including labor) at honda & 2600 at khan market.
I would advice everyone to always put in genuine brake pads.
dhirajs is offline   Reply With Quote
DIY! Sunday Usage! Front brake pad replacement. SirAlec DIY - Do it yourself 10 18th January 2011 21:51
Swift - Wheel Discs and Brake Pad problems ravi23 Technical Stuff 25 18th August 2010 15:07
Getting Rid Of Brake Pad Glaze 1self Technical Stuff 1 26th March 2010 10:05
Early indicator of brake pad failure? tsk1979 Technical Stuff 41 8th December 2009 10:15
Brake Pad wear-out Query? Sahil Technical Stuff 17 20th August 2004 00:23
