Old 13th November 2009, 20:24   #1
nc1bad's Avatar
Thanked: 15 Times
Default Corsa 1.6 cannot maintain idling
Dear All,
I own a 1.6 corsa and am facing a major problem with the vehicle and need urgent assistance.
The vehicle is unable to maintain idling during running / using the vehicle, meaning, the engine switches off when the clutch is pressed during
traffic, turning etc. The service center guys are not able to find the source of the problem and made me change parts unnecessarly.
Parts changed by trial and error method:
1. Ignition Coil
2. Fuel Pump
If anyone knows or has faced a similar problem like this, i would appreciate all the help i can get.Thanks
nc1bad is offline   Reply With Quote
Old 13th November 2009, 20:56   #2
Aarman_008's Avatar
The above problem may occur if the vehicles battery was discharged. Did the service center guys check the battery?
Or the symptom may also occur if there is air intake leak.
Aarman_008 is offline   Reply With Quote
Old 13th November 2009, 21:15   #3
SS-Traveller's Avatar
Thanked: 11,631 Times
Originally Posted by nc1bad View Post
The vehicle is unable to maintain idling...
1. Ignition Coil
2. Fuel Pump
Fuel pump CHANGED because the car won't idle? That's the wierdest... But there can be multiple issues causing this, and need to be eliminated one at a time. The list goes from common to uncommon but does not include everything.
1. Bad petrol/water in petrol
2. EGR valve stuck open
3. Spark plug/plug leads (open and check how they look)
4. Injectors (try using System-G or similar first)
5. Timing belt
6. Valves
Old 16th November 2009, 19:39   #4
nc1bad's Avatar
Thanked: 15 Times
thanks guys, i shall be getting a check list done and update you'll on the same.
Old 16th November 2009, 19:50   #5
Deeps's Avatar
Thanked: 68 Times
Can some others also confirm weak battery as the cause of this problem? I am also facing the same problem in Xeta-cng. My battery is still original and the car is 3 years and 60,000km old. Should I also take a look at the plug cables?
Deeps is offline   Reply With Quote
Old 16th November 2009, 20:00   #6
vdiatech's Avatar
Idle control valve, attached to the TB. remove, it and clean it by spraying a Carb/TB cleaner on it, a fine clean cloth to dry it . If it does not help then the ICV might have to be changed.
vdiatech is offline   Reply With Quote
Old 16th November 2009, 20:43   #7
Deeps's Avatar
Thanked: 68 Times
The IDV is cleaned during routine throttle body cleaning, right?
Old 16th November 2009, 21:25   #8
vdiatech's Avatar
I would hope so, but its hard to trust some mechanics. You could check to see if a TB has been cleaned ( to some extent ), but Idle Control Valve would not be possible to tell by merely looking(without dismantling). So, I am sure, most of the mechanics would skip it if the car does not hav idling problem. Either because they are lazy or have too many cars to fix in a day.
Old 17th November 2009, 21:50   #9
Deeps's Avatar
Thanked: 68 Times
@NC1Bad: Please post here how you solve your problem. Would be beneficial for me and others.
Old 27th November 2009, 16:46   #10
nc1bad's Avatar
Thanked: 15 Times
Default problem solved
hi guys, sorry for the delay but i wanted to be 100% sure before posting.
The problem is solved, i changed the TDC sensor (costs Rs 1500) and the vehicle is now running smooth.
Old 30th November 2009, 12:01   #11
nc1bad's Avatar
Thanked: 15 Times
false alarm guys the problem still persists. help needed!
Old 30th November 2009, 20:41   #12
Thanked: 53 Times
Dude, get the crank sensor checked . does problem occur with AC switch on only? if so the feedback loop to the ECM has to be checked.
dinar is offline   Reply With Quote
Women cannot be arrested after Sunset..! wolfinstein Shifting gears 8 22nd September 2006 15:17
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
Cannot install any version of netscape cheatingdeath Shifting gears 40 12th May 2005 16:20
what are the 2 things that you cannot make do without!! speedsatya Shifting gears 21 12th February 2005 22:58
