| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2004 Location: Mumbai
| For past couple of days, I have been noticing a drop in the My Baleno's pick-up... Its done about 7500 kms in 4 mths and has had the first 2 services.... Initially, i thot it could have been coz of the tyre pressure being seemingly low.. got it topped up yesterday and found the same issue ... could it be coz of the air filter getting dirty/clogged... thanx to all the dirt and grime on account of the Mumbai rains over the past few weeks... wot could probably be the reason ? |
| | #4 (permalink) |
| BHPian | pop open the air filter. Have a look anyway, in my excessive maintainece book, 7500 is time to change the air filter anyway Its always advisable. Considering how dusty the air in BBay is, i am vey particular abt the air filter. I generally try and dry clean (with air or just shake of the dust) every 2.5K and used to change it every 5k. keeps the FE and performance up and expense is low.
__________________ The Swift DZire has a 6 Month waiting period to give you time to seriously reconsider buying something that Ugly |
| | #5 (permalink) |
| BANNED | see if plugs are properly tightened.chek the plug wires, clean the air filter with compressed air,it its clogged. check the timing as well check your fuel lines .cud be a clogged fuel filter also ,though at 7500 kms it is not possible. or it cud also be dragging brakes. try changing the fuel pump.injectors could also be clogged. cu dalso be improper tappet setting. does your engine overheat |
| Thread Tools | |
Similar Threads | ||||
| Baleno FE drop post flood repairs | shuvc | Technical Stuff | 31 | 2nd April 2008 17:26 |
| here comes the drop-out | BillGates | Introduce yourself | 11 | 6th November 2007 20:50 |
| Drop in an ocean | arunkumar_rec | Introduce yourself | 2 | 23rd August 2007 15:33 |
| Can a service cause pick up to drop - Ford Ikon 1.6 ZXI | rkkoul | Technical Stuff | 12 | 14th August 2006 13:14 |
| Drop it like its HOT! | nitroxx | Modifications & Accessories | 9 | 24th October 2005 20:47 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
