Thread Tools
Old 5th August 2005, 10:57   #1 (permalink)
amitoj's Avatar
Unhappy starting problems
Hi guys
For the past few days, i have been facing some serious starting troubles with my zen (carb, 98 model,1.1 lakh kms) . I have to keep cranking it to get it to start. This happens after i have parked the car for about 8 hours. But once the car starts, i can stop and start it n number of times.
I took it to a MASS and they said its a battery problem. So they charged my car's battery for about 7 to 8 hours and also did complete servicing of the car. But the problem still remained. They were still pretty sure that its a battery problem so they replaced the battery with another one (which was a "good" battery according to them). But again no effect. Today morning again i had the same problem.
I am gonna ask them to send a mechanic tomorrow morning so that he can see the problem first hand, coz once the car starts, the problem is gone.
Any ideas what could be the problem?
Amitoj
EDIT: Engine oil was changed at 90K
amitoj is offline   Reply With Quote
Old 5th August 2005, 11:28   #2 (permalink)
11k and you didnt change Engine Oil...
i use to change it every 4K...MAX 5K...
well on my Sister Deo i do it every 1K...
__________________
I live my life a Quarter Mile at a Time...
zulfikar is offline   Reply With Quote
Old 5th August 2005, 11:35   #3 (permalink)
Psycho's Avatar
get your carb jets checked.... also pump the accelerator a couple of times before you try starting.
__________________
Learning is a continuos job that keeps me busy.
Old 5th August 2005, 11:41   #4 (permalink)
amitoj's Avatar
yeah i do pump the accelerator couple of times before starting.
carb jets were also cleaned not long ago. the whole carb setup was overhauled... taken apart and cleaned thoroughly.
will check the engine oil as well. But wait... they did do an oil change when they serviced the car last weekend. thanks for reminding me that zulfi.
Old 5th August 2005, 11:44   #5 (permalink)
Revvhead's Avatar
Even by my excessive standards, a 5K engine oil chage is excessive.
amitoj, i seriously doubt that your problem lies with engine oil.
And considering the amount that you say you are cranking it, there is no way it can be the battery.
What appears to be the problem is more towards the fuel feed.
Since you have a carb Zen, my guess is one of two things.
1. Fuel pump and line. - Its possible that for some reason your fuel line is draining after stopping, so it takes a while for the fuel line to fill up , once its filled up you can restart it easily, or maybe yr fuel pump is slightly weakened, so it takes time initially to fill the empty line. Check that yr fuel line is tightly connected, so that no air creeps in and the line doesnt drain back.
Also check yr fuel filter, may be clogged, casuing a fuel supply blockage initially.
2- Carb jets- as it is a carb zen, i assume that you step on the pedal while starting,
It may be that you are htting a blind spot or have a dirty accelleration jet (i'm not fimiliar with the Zen carb) and thus unable to start immediately. - Use System G to clean out yr jets or clean it out with a strand of wire if you know how.
Anyway, for starters to isolate that problem, try this. a) Start with the Choke on and less acceleartor and see what happens. are you able to start normally??
b) if you know how again- increase the idle speed substantially on the car and try and start
it up without using the gas pedal.
While these are not Fixes, they will haelp you indentify the casue of the problem which sounds very fuel related to me
__________________
The Swift DZire has a 6 Month waiting period to give you time to seriously reconsider buying something that Ugly
Revvhead is offline   Reply With Quote
Old 5th August 2005, 11:45   #6 (permalink)
Revvhead's Avatar
man 2 replies came in while i was typing that long message!!
__________________
Old 5th August 2005, 11:47   #7 (permalink)
iceman91's Avatar
there is a vacuum diaphragm on the carb get that checked...it could be leaking
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 5th August 2005, 12:00   #8 (permalink)
amitoj's Avatar
Umm... in that case when u pull out the fuel inlet (dunno wots the technical term) thats going in, there wont be any fuel right? but there was!
That was also cleaned very recently.
Both dont have any effect on the problem...
This problem is almost making me pull my hair out!
Old 5th August 2005, 12:19   #9 (permalink)
Surprise's Avatar
I never thought cars too have Choke like two wheelers. Is it for only carb version or even for MPFI?
Surprise is offline   Reply With Quote
Old 5th August 2005, 12:19   #10 (permalink)
Revvhead's Avatar
Damn, all options exhasted!! So much for my "technical" advice!!!!
go with what iceman said, sounded more fundoo!!!!
__________________
Old 5th August 2005, 12:20   #11 (permalink)
Revvhead's Avatar
it is for carbs only
__________________
Old 5th August 2005, 12:28   #12 (permalink)
amitoj's Avatar
well, but there has to be something wrong somewhere...
Hey Ice, when the carb gets overhauled, doesnt the diaphragm also get included?
Old 5th August 2005, 12:34   #13 (permalink)
Psycho's Avatar
carb overhaul in Indian terms means cleaning and does not mean any part has been replaced... the easiest way to check if the enrichment circuit is working fine is to open the air cover and rotate the accelerator manualy if you find a squirt of fuel going down the manifold then everything is fine else you will have to overhaul the carb in the true sense.
__________________
Old 5th August 2005, 13:26   #14 (permalink)
amitoj's Avatar
thanks for clearing that up! One more thing (while you are patient!).. do the probs with carb often manifest as starting problems? and that too only if the car isnt started for around 8 hours?
Old 5th August 2005, 13:35   #15 (permalink)
hrag's Avatar
Not exactly sure what kind of ignition the carb Zen has but might be worth checking that. My old carb Omni's points ignition failed twice - all the symptoms were similar. Battery is able to crank and crank, no problems with the carb or the fuel lines.
hrag is online now   Reply With Quote
Thread Tools
Starting as a DJ - Need a turntable.. speedfreak01 Gadgets, Computers & Software 39 3rd July 2008 10:22
Starting problems Indica DLG vfmanuel Technical Stuff 19 13th December 2007 23:09
Doubts about Jump Starting / Push Starting :- mithun Technical Stuff 33 4th October 2007 16:51
Starting problems-Injectors just cleaned,engine flushed rahul_intlad Technical Stuff 16 9th February 2007 11:07
Please help me ! - Long Starting self in Matiz and other problems zzzehar Technical Stuff 12 22nd December 2005 20:15
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
