| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Feb 2005 Location: Chennai
| A wild imagination......... While going at a speed of 60 KMPH in top gear, press you clutch to switch the gear to neutral. Is it possible to engage the gear to reverse while moving forward at 60 KMPH. If that's possible what will happen? ![]() |
| | #3 (permalink) |
| BHPian | very franky......not 2 sure whether thats possible...cause whenever..i confuse my city with the cars i drive in dubai ..and i think im shifting into sixth but actually i shift into reverse i get this bad cracking sound...whick wakes me up bigtime.....the gears box is designed in such a way that u cant switch into reverse if ur wheels r moving too fast in the forward direction atleast u cant switch into reverse smoothly..there will be alot of wear and tear of ur gear teeth because of rubbing as well as heat generation....... but on the other side u can switch into first from reverse comfortably without any trouuble..cause of the syncromesh gear box arrangment.... in the gear box here is a gear know as the md gear that comes from the engine and it is always rotating in one direction only.......there is another shaft in the gear box known as the counter shaft on which the 1st 2nd 3rd and 4th gears are located....the md gear meshes with these 4 gears with the help of dog teeth depending upon the gear that we have chosen..the fifth gear is basically direct transmisiion..it has more than 1:1 gear ration...hence its called overdrive...now the interesting part for engaging into reverse gear the md shaft rotates in the same direction but there is something known as an idle gear which helps in reversing the direction of motion...so when u shift into reverse the idle gear is pushed into action..for this the car has to be best at standstill for smooth shifting or ull get the cacking sound ........thats all drive safe and shift smooth.... allan |
| | #7 (permalink) |
| BANNED Join Date: May 2005 Location: mumbai - bandra
| friend did it once on his santro...from 60 to reverse gotsome breaking sound...the car shut the very moment...was not starting only...he left it for 15-20 minutes...tried to start..it worked...but really screws the gearbox |
| | #8 (permalink) |
| Senior - BHPian Join Date: Dec 2004 Location: pune
| a) If you have Palio/Petra, you can not do that accidently, while downshifting from 5th to 4th (it has a ring type mechanism, which needs to be lifted to shift into reverse). Yes, if you hell bent on doing crashing your gear box, or blowing up engine, you can do that intentionally. b) If you are driving a Santro, you can accidently slot into reverse instead of 4th. My friend learnt it the hard way, when he did at 120kmph on highway. The gear chattering noise was so loud, he pulled car to a side for moment and then resumed. c) No idea about other cars. Note: Dont start Fiat vs. Rest stuff here. I just narrated personal experiences.
__________________ Drive fast, but drive safe. Last edited by RX135 : 5th August 2005 at 23:02. |
| | #10 (permalink) | |
| Team-BHP Support ![]() | Quote:
i haven't tried shifting a manual-transmission car into reverse while driving forward, as i'm scared of ending up with the gear-lever in my hand and the engine flying out of the engine-bay. an automatic-transmission car, however, will not go into reverse while moving forward above a certain speed (>5mph). there is some sort of inter-lock installed to prevent people from doing the un-thinkable. i've tried it on a variety of automatic cars and its the same in each. ad
__________________ Keep your clothes and your boots, I'll just take the motorcycle. Last edited by aah78 : 6th August 2005 at 00:20. Reason: modifying content | |
| | #11 (permalink) | |
| Senior - BHPian Join Date: Dec 2004 Location: Windsor
| Quote:
__________________ Every weapon needs a master | |
| | #13 (permalink) | |
| BHPian | Quote:
__________________ Bajaj Pulsar 200 DTSi Hyundai Verna SX ABS | |
| | #14 (permalink) | |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay
| Quote:
Hey Vivekag, Its definitely possible to shift to N without using the clutch when the car is in motion. It can be pretty hard to do (and not particularly great for your `box), or very easy to do (and not so bad for your `box), depending on how u do it. One way to do it is to just use force to slam the gearshift to N..... not the best way. The bearable way to do it (even though it still remains a pointless thing to do), is like so - By using the accelerator. What you have to do, is get the car to a point where there is neither acceleration nor engine braking happening. For that very slim window, the gearbox has virtually no load on it, and its effortless to push the lever into N. (Just like when the car is parked and you shift the lever without the clutch.) It might be difficult to get to precisely this point, especially in lower gears, so you can trypushing gently yet firmly on the lever and then begin to lift of the throttle. At some point in your deceleration the lever should slot into N. cya R | |
| | #15 (permalink) |
| yeap ... easier to do it in higher gears..can or should be done when there is zero throttle applied .. a light tap is usually enough to slot it in Neutral.
« Pics & Video : Red Bull Formula 1 Car Assembly & Engine Fire-up in Mumbai
Does a Tire/Wheel Upgrade Damage Wheel Bearings?? »
| Thread Tools | |
Similar Threads | ||||
| High speed stupidity | ZedMae | Street Experiences | 10 | 9th June 2009 16:05 |
| Palio 1.6 high speed braking | meremortal | Technical Stuff | 2 | 5th August 2008 18:29 |
| Vibrations at high speed | DCEite | Technical Stuff | 15 | 12th June 2007 17:43 |
| High speed stability of NHC | Floyd de Souza | The Indian Car Scene | 23 | 13th January 2006 11:36 |
| High Speed Course at Driversskill.com | ajmat | Street Experiences | 21 | 3rd July 2005 12:39 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
first the gearbox'll go GRRRRRRRRRRRRRRRR then if u still force it somehow to reverse....CRASH CLINCLE CLANK.....silence.
