Old 18th November 2009, 17:09   #1
jav
Question How much preload for rear wheel bearings?
Hi guys the castellated nut for rear wheel bearings on my indica is extremely tight, i thought that the procedure for tightening tapered roller bearings is to tighten and rotate the drum to seat the bearings and then loosen 1/4 turn and lock with cotter pin, now i am confused should i keep them that tight when i change my wheel bearings now?
T I A
jav is offline   Reply With Quote
Old 19th November 2009, 15:39   #2
T I A
This went totatlly above my head!
harsha.cs1 is offline   Reply With Quote
DIY: Adjusting the Turbo Wastegate / Preload for More / Less Boost dhanushs DIY - Do it yourself 31 5th September 2014 01:05
Does a Tire/Wheel Upgrade Damage Wheel Bearings?? Epic Technical Stuff 40 19th September 2012 15:29
Wierd Sound - Wheel Bearings, Brakes.....??? Epic Technical Stuff 3 16th May 2011 21:05
Wheel Bearings or tyre noise? - Skoda Octavia autozoniac Modifications & Accessories 5 15th May 2006 13:05
