Old 3rd December 2009, 16:42   #16
Eddy's Avatar
Thanked: 5,078 Times
Bump: If its a tie rod, please do not keep driving without alignment.
Update please !
Eddy is offline   Reply With Quote
Old 24th December 2009, 12:16   #17
woof's Avatar
Ah.. completely forgot about this thread. Well, the whole thing (part+labour) costed me around 350 bucks at MASS.
Have gone the alignment done as per your suggestions. And, now car is running as smooth as ever.
woof is offline   Reply With Quote
Old 28th May 2014, 12:02   #18
sriramr9's Avatar
Thanked: 45 Times
Default Concerns, suggestions for damaged front left wheel.
Last day yet another unfortunate incident happened at crawling speed when tried negotiating a left hand turn, front left wheel crawled on top of a weak man hole cement cover (storm water drainage) which crumbled (newly done and no indication like cone or barricade was kept that would have alerted me.) and the car itself fell and got stuck.
After lots of human help, burning rubber and burning of clutch the car was pulled out to safety. i visually inspected and found the engine guard to be bent. The mud guard was not broken (black plastic), no scratches in alloy at least visually. As i drove home the remaining distance i did not get any warning. But i could sense burning smell coming from somewhere, not sure where.
Questions: What i should check immediately. please clarify. is there anyway where i can post a complaint about the bad work done by the road authorities of not having put up a visual hazard warning ? It was so dangerous, as it was in dead middle of the road entrance and people who live in that particular lane where so careless to be plying on the sides without taking any steps ?
sriramr9 is offline   Reply With Quote
Old 28th May 2014, 12:48   #19
ghodlur's Avatar
Thanked: 2,439 Times
Red face Re: Concerns, suggestions for damaged front left wheel.
Sad to hear about the incident Sriram.
You need to get the suspected wheel balancing and alignment checked if there is no visual damage observed. Have you ensured that apart from the stone guard, nothing has gone bad like coolant/liquid dripping etc. When you drove hoome did you notice any difference in the ride quality apart from the burning rubber smell? Most probably the clutch pads must have been smoked when you tried to get the car out of the manhole.
A visit to Fiat workshop can sort out any doubts.
ghodlur is offline   (1) Thanks Reply With Quote
Old 28th May 2014, 13:00   #20
Thanked: 14,610 Times
Default Re: Concerns, suggestions for damaged front left wheel.
Originally Posted by sriramr9 View Post
Last day yet another unfortunate incident happened at crawling speed when tried negotiating a left hand turn, front left wheel crawled on top of a weak man hole cement cover (storm water drainage) which crumbled and the car itself fell and got stuck.
I visually inspected and found the engine guard to be bent. The mud guard was not broken (black plastic), no scratches in alloy at least visually. As i drove home the remaining distance i did not get any warning. But i could sense burning smell coming from somewhere, not sure where.
Check the suspension, lower arm specially, drive shaft for damage. May be due to this fall some rubber past is touching the hot engine and burning slowly or the tyre is rubbing against something.
I don't think even if you complain anything substantial will happen but may reach the ears at least. Good that the incident happened in the car, had it been a 2 wheeler conditions and situations would have been worse today.
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 28th May 2014, 13:07   #21
IshaanIan's Avatar
Thanked: 3,395 Times
Check the lower arms, stabilizer bars, the brake rotor and remember to get balancing and alignment done. Sorry to hear about this mate!
IshaanIan is offline   Reply With Quote
Old 28th May 2014, 13:08   #22
sriramr9's Avatar
Thanked: 45 Times
You need to get the suspected wheel balancing and alignment checked if there is no visual damage observed. Have you ensured that apart from the stone guard, nothing has gone bad like coolant/liquid dripping etc. When you drove home did you notice any difference in the ride quality apart from the burning rubber smell? Most probably the clutch pads must have been smoked when you tried to get the car out of the manhole.
Could not test drive quality thoroughly as it was crowded and i was running at high temperature, was still looking for warnings in dash none as of now, today morning checked for leaks but nothing on the ground, did not open bonnet and check. Will have to get the wheel balancing and alignment done for sure, is there a way to find a difference in driving after burning the clutch, i tried but could not? But there was substantial rubber burn from front left tire
yes i tried, all i could see from outside was a visual bend of the engine guard., not sure on the lower arm, will get it checked tommorow when i will be taking it, thanks for that pointer.
I did complain to the doctor whom i visited whose clinic was in proximity to the accident scene to inform the authorities to at least to put a hazard warning at the earliest so motorists don't fall inside.
Old 28th May 2014, 13:14   #23
Complain to the traffic police department from their website. Not sure if it'll work but try.
Drive around for a while and see if the left tyre is hot. If it is then the tyre is rubbing against something.
Anurag.
Old 28th May 2014, 13:36   #24
sriramr9's Avatar
Thanked: 45 Times
Anurag.
Will drive tomorrow and post feedback here, i generally baby the engine a lot, substantial idle during cold starts and after driving, never have slipped the clutch intentionally, never over rev on any conditions, yest all that abuse was done with in 5 mins of time, premature engine shutdown after high revvs, extended huigh revving and burning the clutch all at the same time.http://www.team-bhp.com/forum/images...rustration.gif
Old 28th May 2014, 16:09   #25
Default Re: Noisy Swift after going over a pothole at high speed
Hi Sriram,
Sorry to hear this incident. Kindly check the forearms and wheel alignment. Also check if there is any bumper damages too. Don't make any long drives before checking with the service person. Similar case to one of my friends happened recently for which he has paid 3000 rs for changing the tyre. You can lodge a online complaint in Corporation of Chennai portal and it will be resolved positively.
Ashwin
ashwin.raj80 is offline   (1) Thanks Reply With Quote
Old 28th May 2014, 19:04   #26
sriramr9's Avatar
Thanked: 45 Times
Sure, Ashwin_raj, i shall post a complaint and shall post the web link here. as far as i can guess there was substantial tire and clutch wear with the distinct burning smell.
Planned to get checked following things,
1. Oil levels, all oil levels,
2. Denting of engine guard.
3. inspecting left lower arm for visual damage for repair.
4. Suspension check (any specifics here ?) including mounts.
5. check for any rubbing with front wheel on account of the underbody damage.
6. Check tire pressure and in case of puncture to fix the same.
7. Wheel alignment and balancing.
8. repairing plastering scratches in front bumper.
Anything more pl also mention.
Old 31st May 2014, 22:17   #27
sriramr9's Avatar
Thanked: 45 Times
Hi All
Had an inspection done to the under body, this model of fiat cars were provided with a metal plate that took the weight of the car, i was 100% fortunate in this case. Lower arm was not touched in this case as the car's left wheel was the victim, had it been the right hand side the vehicle would have rested on the lower arm directly.
Thanks FIAT for the metal plate in the under body.
1. Oil levels, all oil levels, (No issues found)
2. Denting of engine guard. (A special tool was used to pull out the dent)
3. inspecting left lower arm for visual damage for repair. (None, the metal guard took the abrasion and beating)
4. Suspension check (any specifics here ?) including mounts. (No issues no squeaks, noise, screech found while driving on rough surfaces.)
5. check for any rubbing with front wheel on account of the under body damage. (None)
6. Check tire pressure and in case of puncture to fix the same. (None)
7. Wheel alignment and balancing. (Done)
8. repairing plastering scratches in front bumper.(Next visit.)
Posting pictures of the manhole, dented metal plate the repaired and under body coat done post repair and alignment balancing.
Old 31st May 2014, 23:03   #28
Congrats and good to see the car back in action.
3. (None, the metal guard took the abrasion and beating)
I advice you to get a NEW metal guard as the damage once done to these crucial parts will loose out their integrity/structural strength and MAY NOT work as required in an event if such incident happens.
4. Suspension check (any specifics here?)
None other than lower arms.
Check the wheel and tyre for roundness and any bulges on the tyres due to impact.
Anurag.
a4anurag is online now   Reply With Quote
Old 1st June 2014, 00:15   #29
sriramr9's Avatar
Thanked: 45 Times
Sure anurag, I got the wheel alignment and balancing done I will post the pics on those. Only the toe was beyond tolerance and the same was duly corrected and weights added
Now the car is 2.5 years old and we did check the metal protector plate strength. It sounded taut and strong. Being made of cast iron I understand it should some more years of service life.. Correct me if I am wrong
Old 5th June 2014, 14:30   #30
joybhowmik's Avatar
Thanked: 1,928 Times
No. Cast iron is by nature brittle - not malleable. Now that the dent is pushed out, if you were to put the part to more stress it will fracture. Had it been made of steel , that would have been different.
joybhowmik is offline   (1) Thanks Reply With Quote
Hit pothole at speed, tyres severely damaged noblecr Tyre & Alloy wheel Section 60 7th February 2015 13:40
Bent Rim after hitting a pothole - What effect will it have on the tyre? Bigzero Tyre & Alloy wheel Section 17 14th January 2015 17:06
From Humming @ Hampi to Jogging at Jog to going Gaga over Goa to ambling over Amboli vnabhi Travelogues 108 3rd December 2009 17:59
Noisy Swift Diesel rajatsingh78 Technical Stuff 38 11th July 2008 17:44
Swift in Hole (Pothole) Kool_Kid Street Experiences 5 8th July 2008 15:42
