Old 5th June 2014, 14:46   #31
Thanked: 688 Times
Originally Posted by woof View Post
But, afterwards when I drove it over uneven road surface, a irritating screeching noise came from the front left wheel. What could be the problem? There seems to be no visible damage. What can be the issue?
Could be your shock absorbers are damaged. I had this on my Fiat Uno. Take it to your MASS.
Sent from my iPhone using Team-BHP
gsurya is offline   Reply With Quote
Old 5th June 2014, 15:18   #32
woof's Avatar
Default Re: Noisy Swift after going over a pothole at high speed
Lol ! You have responded back on 5 year old thread!
woof is offline   Reply With Quote
Old 6th June 2014, 15:36   #33
sriramr9's Avatar
Thanked: 45 Times
Originally Posted by joybhowmik View Post
No. Cast iron is by nature brittle - not malleable. Now that the dent is pushed out, if you were to put the part to more stress it will fracture. Had it been made of steel , that would have been different.
The car went & sat on the ditch at 5 kph speeds. The vehicle is also 2.5 years old now. that made me think that there should be some more service life left on the protector plates strength, also during inspection, upon mild hammering the protector plate did not show signs of age or there were no rust chips falling down.
Well Agree to your point on the quality of the iron used for the plate. it should definitely not have been a malleable cast iron for sure being an auxiliary component ..
sriramr9 is offline   Reply With Quote
Hit pothole at speed, tyres severely damaged noblecr Tyre & Alloy wheel Section 60 7th February 2015 13:40
Bent Rim after hitting a pothole - What effect will it have on the tyre? Bigzero Tyre & Alloy wheel Section 17 14th January 2015 17:06
From Humming @ Hampi to Jogging at Jog to going Gaga over Goa to ambling over Amboli vnabhi Travelogues 108 3rd December 2009 17:59
Noisy Swift Diesel rajatsingh78 Technical Stuff 38 11th July 2008 17:44
Swift in Hole (Pothole) Kool_Kid Street Experiences 5 8th July 2008 15:42
