Old 20th November 2009, 11:38   #1
woof's Avatar
Default Noisy Swift after going over a pothole at high speed
Today morning, on the way to my workplace, I accidently drove my car - Swift Vdi - into a pothole. There was a loud thud noise from the front left wheel.
I pulled over and inspected the car, and found no damage.
But, afterwards when I drove it over uneven road surface, a irritating screeching noise came from the front left wheel. What could be the problem? There seems to be no visible damage. What can be the issue?
woof is offline   Reply With Quote
Old 20th November 2009, 11:40   #2
Eddy's Avatar
Thanked: 5,068 Times
It could be a damaged mudflap rubbing against the wheel in motion
Eddy is offline   Reply With Quote
Old 20th November 2009, 11:48   #3
shishir_bn's Avatar
Thanked: 108 Times
May be some rubber bush might have come out/cut/damaged
shishir_bn is offline   Reply With Quote
Old 20th November 2009, 12:04   #4
woof's Avatar
No, its not. I checked the mudflap - it was in its place.
Old 20th November 2009, 12:16   #5
Your lower arm bush might be damaged. If you run your car with this problem, it may lead to uneven tyre wear. Inspect your car with your authorized service cener immediately.
Ramesh75 is offline   Reply With Quote
Old 20th November 2009, 15:30   #6
ksethuram's Avatar
Open the bonnet and see if anything like horn is loose. If nothing is loose it is better to visit a mechanic immediately.
If the suspension is the one causing the noise then i am sure the hole should be a nasty one.
ksethuram is offline   Reply With Quote
Old 21st November 2009, 14:31   #7
sudharma's Avatar
You may have rim damage and or suspension damage.Checkout the Mcpherson Strut for damage as well.
sudharma is offline   Reply With Quote
Old 21st November 2009, 14:46   #8
sudev's Avatar
Thanked: 2,645 Times
Best to get it inspected at a garage. Unless you put it on a lift or slide under the car some damages may not be apparent. Since the noise is directly associated with going in to pot hole the chances of suspension are high.
sudev is online now   Reply With Quote
Old 21st November 2009, 19:42   #9
BenjiRoss's Avatar
Thanked: 161 Times
Do you find that the car is pulling to one side when you leave the steering and drive (do this only on an empty road that is straight and has no tilt .
If it does pull, get your suspension checked completely. If you keep driving you run the risk of wearing out the tyre very quickly.
BenjiRoss is online now   Reply With Quote
Old 22nd November 2009, 21:57   #10
woof's Avatar
The car is not pulling to one side. Its running smooth. At lower speeds, there is no noise at all. But, whenever I accelerate the car to over 70-80 km/hr speed, I can hear knick-knack screeching type of sound.
Will be taking the car to MASS tomorrow.
Old 23rd November 2009, 18:50   #11
Eddy's Avatar
Did you get a check up done ? Update ?
Old 24th November 2009, 15:16   #12
woof's Avatar
Naah yaar. Just couldn't find enough time. Planning to go tomorrow to Saya MASS.
Old 1st December 2009, 16:27   #13
woof's Avatar
Got it checked last week. Problem diagnosed - One of the rods (don't know what it is called) near the wheel was bent, got it replaced. Now, the car is functioning as smooth as ever.
Old 1st December 2009, 16:49   #14
Eddy's Avatar
Tie rod ?
How much did it cost ? And did you get alignment done post that ?
Old 1st December 2009, 17:01   #15
Nikhilb2008's Avatar
Thanked: 6,615 Times
Even I would like to know how much it cost. And make sure oyu get wheel alignment done asap. Otherwise, your tyre could wear unevenly.
Nikhilb2008 is online now   Reply With Quote
Hit pothole at speed, tyres severely damaged noblecr Tyre & Alloy wheel Section 60 7th February 2015 13:40
Bent Rim after hitting a pothole - What effect will it have on the tyre? Bigzero Tyre & Alloy wheel Section 17 14th January 2015 17:06
From Humming @ Hampi to Jogging at Jog to going Gaga over Goa to ambling over Amboli vnabhi Travelogues 108 3rd December 2009 17:59
Noisy Swift Diesel rajatsingh78 Technical Stuff 38 11th July 2008 17:44
Swift in Hole (Pothole) Kool_Kid Street Experiences 5 8th July 2008 15:42
