Old 21st November 2009, 22:51   #31
VEA
Thanked: 32 Times
Originally Posted by narry View Post
hi
first a person or a company who buy s class benz any were in the world yes i say any were in the world does think of economy or something like this because this s class is for the higher economic or higher end of the market
now if u ask what would u choose a petrol v8
or new generation deisel v8
my answer would 100 percent deisel
why?
because the kind of pickup and a torque u get in new generation diesel engine a petrol cannot match also for example u say 0 to 100
in 10 seconds and 0 to 100 in 12 secounds
for a car which use in road 0 to 100 1 or 3 secound does not matter because u are going to use car in a road not for racing
but if i had deisel car it has more torque
so less gear changes better pick up
increase driving pleasure
also a deisel give better fuel economy than petrol imagine u have v8 s class with approx 80 liter fuel tank full tank can give u may be 700 km range but same car
in deisel with 80 liter fuel tank can give 1100km range so u donot have go offten to fuel station offen this what makes new diesel better in my opinon but is last more about personal taste
narry
Im sorry, i must have specifically mentioned economic sense for the manufacturer here.
VEA is offline   Reply With Quote
Old 13th September 2012, 17:03   #32
Thanked: 103,672 Times
Default Re: Why are V8 diesels a rare breed?
So, the Cayenne is soon to come with a V8 diesel. 850 Nm of torque and 0 - 100 in 5.7 seconds! Not bad for a large, heavy SUV.
More Information
GTO is offline   (2) Thanks Reply With Quote
Old 13th September 2012, 18:39   #33
SR71A's Avatar
Thanked: 72 Times
MOre than V8s are probably used only in Marine, Heavy earth overs, static generators and Tanks. Like the humungous 48 Ltr v12 MTU unit that powers the Arjun MBT.
Interesting to see how far diesels have come that they are beating petrol driven units in speed and reliability.
SR71A is offline   Reply With Quote
Old 17th October 2012, 13:37   #34
Thanked: 12 Times
I guess the big TDi V8s are being reserved for very specific applications. Besides, an inline 6 diesel motor has an inherent balanced feel to it. Torque is a problem as these V8s can produce gobs of it at ridiculously low rpms necessitating the need for advanced and intelligent gearboxes to avoid mechanical failures. Also, these are sophisticated motors expensive hardware bolted on them resulting in higher development and production costs. Therfore it all ads up to one conclusion - V8 diesels are the cream of the crop!
Raag Sandhu is offline   Reply With Quote
Old 17th October 2012, 14:53   #35
.anshuman's Avatar
Thanked: 9,159 Times
More Information
And BMW has taken a different path with peformance Diesels. Instead of increasing cubic capacity or cylinders they have added a triple turbo to extract 740nm of torque from the existing 3000cc V6 Diesel.
Under the hood of X6 M550d this engine makes this car faster than even Audi Q7 V12. Going by the reviews from Europe, the turbos' are setup brilliantly without any signs of lag anywhere in the rev range, top end is told to be as potent as the Petrols.
Last edited by .anshuman : 18th October 2012 at 17:32. Reason: Had posted twin turbo instead of triple turbo. fixed now.
.anshuman is offline   (1) Thanks Reply With Quote
Old 2nd February 2015, 11:20   #36
So, the VW Touareg (aka Porsche Cayenne in more subtle clothes) was sold with a V10 diesel at one time. The V10 variant went through a lot of ups & downs, which sort of provide answers to why we don't see that many V8 / V10 diesels.
1. It was heavy!! The Touareg V10 weighed 300+ kilos more than the V6.
2. Because of the additional weight, it was front-heavy & a poor handler.
3. The kind of power that the VW V10 made (300 BHP, 750 Nm of torque) is 'nearly' possible with V6 diesels.
4. The V10 diesel was a fuel guzzler.
5. It was pulled off the USA market twice because it couldn't meet newer emission norms.
6. The VW V10 was a maintenance nightmare.
Here's a video of the V10 towing a plane!
GTO is offline   (3) Thanks Reply With Quote
Old 3rd February 2015, 14:06   #37
rangakishen's Avatar
Thanked: 96 Times
Hello,
One reason that i dont think has been discussed here is the actually motivation for increasing the number of cylinders.
The most basic reason for the increase in the number cylinders was to decrease the inertia in the engine so that it would be able to rev higher. That is, the mass was more distributed (more cylinders) and hence there was less moment (lesser concentration of mass).
And the main motivation for the above is - higher the rpm, higher the power (rate at which work is done).
But in a diesel, the speed of the engine is anyway limited. And the construction is more sturdy and heavy. There is no need to increase the number of cylinders. Other factors can be changed if more power or torque is needed.
That is the reason even the volvo buses come with v6 engines. As the engine speed requirement is low, there is no need for more number of cylinders. Unless of course there is a need for MUCH more power.
rangakishen is offline   (1) Thanks Reply With Quote
Old 3rd February 2015, 20:09   #38
dhanushs's Avatar
Thanked: 4,506 Times
^^ Add to it the weight & balancing factor, which I guess for fast cars is and issue.
A new breed of high performance electric car - Tango prguru The International Automotive Scene 7 19th August 2011 14:15
Truck Diesels vs. Car Diesels smashnerd Technical Stuff 7 15th January 2011 16:41
A new born in a dying breed: Tiburon goes RWD Mpower The International Automotive Scene 32 9th August 2007 01:38
New Breed of Designers SRK Shifting gears 4 17th December 2005 21:09
