Thread Tools
Old 9th August 2005, 11:30   #1 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Default Slow indica
Hi guys,
My indica used to give mileage of 13-14 in city and have a top whack of 140(Speedo reading, actual around 132). After the service the mileage has increased to 15+ and the top speed is around 115(Speedo). I went to the workshop and told them that i dont mind the mileage drop but return the top speed. But after many adjustments they cant seem to get it. Is there anything specific setting which needs to be changed? I figure they have screwed up something with the air fuel mixture.
__________________
Old 9th August 2005, 11:45   #2 (permalink)
Surprise's Avatar
Originally Posted by tsk1979
Hi guys,
Man, you would have gone for PALIO
Surprise is offline   Reply With Quote
Old 9th August 2005, 11:49   #3 (permalink)
amitoj's Avatar
yeah ur car might be running on wot they call a "lean" mix of fuel n air. U want to make it "rich".
amitoj is offline   Reply With Quote
Old 9th August 2005, 11:51   #4 (permalink)
turbo_lover's Avatar
yeap..its running lean ..
take it to a roadside mechanic he will make it rock ...minor tuning required .
__________________
Every weapon needs a master
turbo_lover is offline   Reply With Quote
Old 9th August 2005, 11:51   #5 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Nope, i am on diesel, therefore i dont mind the mileage drop . As for the palio, the palio diesel is way too expensive. I bought the indica diesel for 3.5Lac. If i plan to spend so much i would rather go for the indigo
__________________
Old 9th August 2005, 12:11   #6 (permalink)
Surprise's Avatar
Sorry the intention is not to question your purchase & got the way you think about it.
Is this alterteration affect only the top speed or even the pick up? Will this tuning have any long term impact on the performance?
Old 9th August 2005, 12:26   #7 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Hehe, no sweat dude. Actually it should affect the pick up too. My indica is currently jerky in hills which is a typical sign of lean mixture. The workshop guys seem to be die hard environmentalists. Roadside mechanic it is!
__________________
Old 9th August 2005, 12:42   #8 (permalink)
It can be more than what meets eye. Whatever your road side mechanic can do, the workshop folks can definitely do, especially if it's a trivial stuff as minor adjustment. I will recomment against doing that, unless you are sure about this roadside mechanic. Just a thought!
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 9th August 2005, 12:56   #9 (permalink)
Surprise's Avatar
I too voice the same opinion of RX135.
Old 13th August 2005, 17:24   #10 (permalink)
ananthkamath's Avatar
Go to a fuel-injection pump service specialist...they may be able to solve your problem....
A guy I know (and trust!) has fitted a MICO pump(will get you specifics if you want) to the Indica diesel as opposed to the Lucas-TVS one...He says the bottom-end is much better and the car doesn't stumble when the AC is switched on below 1500 RPM....Fuel cons. increases by 1-2 km/l which is negligible.....
Ananth
ananthkamath is offline   Reply With Quote
Old 14th August 2005, 01:41   #11 (permalink)
Team-BHP Moderator
tsk1979's Avatar
wow, can you tell me the details? Which pump is it and where's this guy? How much did it cost? At Around 80-90K kms the fuel pump overhaul comes up which will cost 7K. So i may as well get a new fuel pump then!
__________________
Old 14th August 2005, 02:07   #12 (permalink)
gr8guzzler's Avatar
He knows its lean...and he's asking for how to make it rich.....
TSK no idea.....guess guys like Pshyco or Dom can respond better
Cheers!!!
__________________
Kishore
gr8guzzler is offline   Reply With Quote
Old 15th August 2005, 18:51   #13 (permalink)
Cheers!!!
Well I'm just sharing my $0.02, that's it. If Psycho or Dom can pitch in with other useful info, its just as well for TSK.
TSK, about the Pump: Its a MICO distributor-type rotary pump from the Tata Sumo, or Peugeot (Jeep). There are some minor differences between these two pumps but once you fit it , it doesnt matter, you HAVE to calibrate it to the Indica engine. Only an adapter plate needs to be made as the mounts are different. My friend who runs a garage in Mysore has done this to a couple of vehicles and the customers couldnt be happier...
Old 15th August 2005, 22:35   #14 (permalink)
dadudeonfire's Avatar
even i had an indica bro...its a real sad car...so many problems it had given me...unbelievable dude...top speed became 80...hhahaha...trust me...but it was driven 85k...and not even v2
dadudeonfire is offline   Reply With Quote
Thread Tools
Slow Performance On MY Swift ? Need Help viper316 Modifications & Accessories 7 25th January 2008 07:24
Santro Slow Speed ajitsank Technical Stuff 8 18th September 2007 22:10
Slow Poke Rash Introduce yourself 10 7th November 2006 03:28
Ferraris are slow arun Introduce yourself 10 27th October 2004 19:27
who said Boxters were slow??? turbolader The International Automotive Scene 3 28th July 2004 03:37
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
