Old 24th November 2009, 08:29   #1
aroop's Avatar
Thanked: 19 Times
Cool Wagon R Clutch problem?
My Sep 2007 Wagon R (12k km) has developed a problem (I am not sure if its right to call it a problem). While driving, when I initially release the clutch (while pressing the accelerator, of course), the vehicle does not move; the power comes only at the end of the release.
I have driven some other cars (Zen Estilo, Alto), this problem isnt there. What could be the issue?
Please let me know what I should be asking for at an A.S.S. so that I am not taken for a ride.
Aroop
aroop is offline   Reply With Quote
Old 24th November 2009, 11:36   #2
sushrutha's Avatar
Thanked: 325 Times
Aroop
Nothing wrong with the car.
Take it to a service station & get you clutch adjusted.
Old 24th November 2009, 16:00   #3
Sushrutha, I had been informed that the clutches in these modern vehicles are self-adjusting. But i perhaps there still might be some scope for manual adjustment or what?
harsha.cs1 is offline   Reply With Quote
Old 24th November 2009, 16:49   #4
MCR
Thanked: 237 Times
Had the same issue in my 9 month old alto. Just adjust the clutch play and everything will be allrigt.
MCR is offline   Reply With Quote
Old 25th November 2009, 07:36   #5
aroop's Avatar
Thanked: 19 Times
Thanks for the inputs. Though I am not competent to adjust it myself, I will ask my local mechanic to do it.
Aroop
Old 25th November 2009, 08:28   #6
prince_pervez's Avatar
Thanked: 34 Times
No big deal take it down during your regular service. If the problem persists then we have a problem. 12K is too early for these sort of problems unless the driving style is out of the ordinary.
prince_pervez is offline   Reply With Quote
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Clutch Problem in Wagon R snaronikar Technical Stuff 9 10th August 2007 16:38
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
