Old 24th November 2009, 17:28   #1
Default Braking issue with my Skoda Octavia
I own Skoda Octavia Rider car, whenever I apply brake in Speed Brake or in any ups and downs on the road, my brake jumps and this hurts my leg. This happens only when I apply brake in Speed Brake or in any ups and downs on the road. Can anyone suggest me on how to resolve this issue???
classic_rider is offline   Reply With Quote
Old 24th November 2009, 18:56   #2
ksethuram's Avatar
Are you pretty sure that it is not the ABS which is pushing your pedal back?
It is normal to feel pulses through the pedal when abs becomes active. If it is not the ABS pulse you are feeling i suspect the ABS unit may have given up.
Also please check whether there is any dust in the abs pickup sensor and the grooves in the axle are clean from any sticky substance.
You will have to go under the car or lift the car to check this.
It is better to have it checked in your skoda garage.
ksethuram is offline   Reply With Quote
Old 24th November 2009, 19:36   #3
If I apply the brake in up's and down's on the road, the car slows down, during this process the brake usually jumps, hence my leg jumps as well from the brake and I loose control over the brake and car moves fast.
Let me take my car to Skoda service center for check up.
Pulsar 220 F inadequate rear braking issue! makanaka Motorbikes 20 2nd June 2017 13:51
Skoda Octavia 1.8 TSi DSG - Shuddering issue! docsr Technical Stuff 74 3rd January 2017 22:01
scorpio braking issue zenopio Technical Stuff 7 3rd June 2007 21:01
