View Poll Results: how would you like your ECU to behave?
just take care of fuelling 0 0%
keep track of everything but let me decide how to handle an error 13 65.00%
do all the thinking for me 7 35.00%
Voters: 20. You may not vote on this poll
Old 26th November 2009, 19:15   #1
Thanked: 12 Times
Default intelligent ECUs. how intelligent?
I just saw a brand new Ford Ikon today that came to a friends shop for the customary stereo and remote locking change.
everything went well until - for some reason - the CEL came on and stayed on. nothing the fitters did or undid after that got rid of the light.
the RPM ended up limited to 2000. Im guessing it was the ECU's limp mode in action. the engine sounded and felt normal, so I reckon it was an electrical problem.
now here's my crib: why dont manufacturers give the user a provision to find the exact error code?
lately, the trend is for ECUs to handle almost everything in the car, not just fuelling. I personally find this excessive. why not have 3 modes where the driver decides to override limp mode always or manually [risking warranty, of course] or let the ECU handle everything?
my car does not like the concept of a TPS. it finds new and imaginative ways to break any TPS I attempt to attach to it. I have 5 broken TPSs in my collection so far. this means that the CEL is always on, but I love the fact that I can still have a ball without having to bother about a nanny ECU imposing limp mode on me. by the way, Ive also pulled two wires from that little socket on the passenger side and connected them to a switch so that I can get the error code without having to resort to gymnastics and short the wires every time. Im especially happy that it is nothing like some ECUs that instantly shut the car down and/or lock all doors at the slightest whiff of a problem.
this is really a matter of personal preference but Im really interested in finding out how you folk like your ECUs. rare, medium or well done.
blacmagic is offline   Reply With Quote
Old 26th November 2009, 19:22   #2
ssjr0498's Avatar
Thanked: 118 Times
I am quietly and closely following this thread!!! I would pesonally want my ecu to give me the option of doing what I want when a error is thrown.
As of now, I am enjoying the launch controll and a 8500rpm redline
Shrey
ssjr0498 is offline   Reply With Quote
Old 26th November 2009, 19:25   #3
Thanked: 12 Times
Shrey, 8500 RPM?? so you finally have your hands on an RD 0901 I see. lucky man.
Old 26th November 2009, 19:29   #4
ssjr0498's Avatar
Thanked: 118 Times
Nah!! I have the 0601, currently I have removed it, it's only for some special saturday/sunday nights!! You know what I mean!!
Old 26th November 2009, 20:40   #5
motophsyco's Avatar
Nice to know you are revving to 8500, but are you making any power past your redline? Or is it just for the sake of bragging? A real dyno chart should be accompanied with such claims to seek some credibility. Atleast, will prevent others from trying to copy the same and ending up with blown engines after reading such posts.
motophsyco is offline   Reply With Quote
Old 26th November 2009, 23:28   #6
Thanked: 12 Times
folks, if you have the time, it would be much more informative and useful if you elaborated the reason behind your choice.
Old 26th November 2009, 23:33   #7
Shan2nu's Avatar
Thanked: 87 Times
LOL, no way. He just said that he revs to 8500. The engine must be maxing out below 7500rpm.
Shan2nu
Old 26th November 2009, 23:43   #8
ssjr0498's Avatar
Thanked: 118 Times
No braggin no nothing!! No one makes peak power at the redline man!! I was just saying that im enjoying the 8500rpm redline. Like Shantanu said, no way am I producing anything after 7500.. so chillax bro!!
Cheers,
Shrey
Old 26th November 2009, 23:55   #9
Shan2nu's Avatar
Thanked: 87 Times
I chose option 3.
I would want the ECU to decide how the engine should perform in case of an error. I wouldn't like to take a chance by driving my car when the ECU thinks otherwise. I'd rather drive in limp mode than risk damaging the engine.
I dont think the ECU will limit engine performance to a large extent unless there is a good enough reason. When my 02 sensor failed, all i saw was a yellow light on the dash.
Engine performance didn't get affected much. The ECU used to alter the settings when the engine warmed up and the engine would run as usual.
Shan2nu
Old 27th November 2009, 00:45   #10
pranavt's Avatar
Thanked: 272 Times
Get a better cam and you would make power after 7.5k, which I'm sure he knows. Shrey, what brand valvesprings? Aftermarket retainers?
As for the ECU, let it handle fuelling, ignition and reporting data on various sensors. I will choose what to do with the errors. However, limp mode is really nice since you get a stock fuel/ign map with open-loop, so you can always run your car to your nearest service center even with multiple sensors unplugged. My ITB'd car was driven about a km in limp mode with a couple of sensors disconnected, hardly any vacuum, no suitable fuel/ign maps and no IACV.
So I'd say:
Fuel + Ignition + Datalogging + Limp mode + various general-purpose inputs/outputs to configure/setup and run various aftermarket/custom things through the ECU itself.
My Honda ECU lets me remap and datalog. Features like launch control, tps/alpha-n based mapping, etc. Plus, usually 3-5 inputs/outputs to control various things like full-throttle-launch, switching to secondary fuel/ign maps (street/race mode kind of thing), direct wideband logging through ECU with analog (voltage-based)/ serial inputs, etc.
Old 27th November 2009, 00:53   #11
Thanked: 12 Times
Shan, good points. an ECU designed with common sense is good to have. that said, how many ECUs around are designed with common sense?
I remember reading about a Superb simply shutting down abruptly and refusing to start, a Bimmer crashing and burning its passengers alive because the ECU decided to lock all doors thats what I mean when I say "nanny ECU". I dont know why the Ikon I saw today went limp. shall update when I come to know and then discuss whether limp mode was warranted.
another thing I dont understand is why dont companies give the customer specific error codes instead of throwing up a light that could mean anything from a snapped speedo cable to loss in oil pressure? doesnt a customer deserve to know? rather, they make such a big deal of retrieving the error code that it looks like rocket science while the truth is that its extremely easy to retrieve the error code - in our OHCs at least.
Pranav, what ECU again? Honda?!
Old 27th November 2009, 00:57   #12
Canned Heat's Avatar
@ Shan2nu. its the preferred way by all manufacturers now due to OBD 2 specs. Its mainly due to the emission control systems. Any small problems are takbe care of by open loop or closed loop systems. Major faults cause the ecu 2 revert to limp home modes. OBD 1 used MIL flashing.
Canned Heat is offline   Reply With Quote
Old 27th November 2009, 02:04   #13
pranavt's Avatar
Thanked: 272 Times
Yes, chipped Honda P28 running eCtune, previously CROME.
Old 27th November 2009, 19:19   #14
Thanked: 89,535 Times
Shrey, your post reminds me of an interesting ol' thread on increasing the OHCs revv limit. Take a look - 8300 rpm Honda City (Increased the revv limit of a Honda City) - Must read.
Intelligent Tyres....... Shan2nu Tyre & Alloy wheel Section 9 12th April 2010 01:18
Software and ECUs in automobiles Volt Technical Stuff 2 8th February 2009 20:02
Intelligent Light Booster System For Car Headlight ankitahuja Modifications & Accessories 15 15th January 2009 15:59
DaimlerChrysler's - INTELLIGENT NIGHT VIEW Surprise Technical Stuff 5 4th January 2007 18:41
Intelligent Speed Humps bigman Shifting gears 4 9th November 2005 10:08
