Old 26th November 2009, 21:18   #1
honkinDpothole's Avatar
Default Zen pickup problem. Please help!
Hello guys!
I have a Zen (MPFI) with all stock engine. I face a very peculiar problem with it, after lot of clutch use in city's stop and go traffic, the engine start jolting during pick up in first gear and I have to press clutch immediately and start releasing again carefully.
This problem is gradually spreading to 2nd gear as well . My daily drive is about 50km but this problem is giving lot of pain.
Need help from experts!
Ravi
honkinDpothole is offline   Reply With Quote
Old 26th November 2009, 21:59   #2
Thanked: 186 Times
Have the clutch bearing checked , how much has the car run (KMS) ?
wbd8779 is offline   Reply With Quote
Old 26th November 2009, 22:20   #3
Got clutch plate replaced about a year back. Car has completed 72,000KM.
Old 26th November 2009, 22:23   #4
Thanked: 49 Times
The clutch bearing has nothing to do with this. A bad clutch bearing will just cause noise when the clutch is pressed.
It looks like your clutch plates are worn out. Have it checked at a reliable MASS.
CrackedHead is offline   Reply With Quote
Old 26th November 2009, 22:38   #5
Clutch plate is about one year old and has done only 12-14k KM.
Old 19th February 2010, 20:46   #6
Default Zen pick up problem
Hi friends,
I have 2001 Zen VXI (MPFI)which is clocked 60,000km. My problem is that engine rpm rises quickly but not speed respectively.Is it problem in clutch?Is it best solution to replace clutch ***.and clutch release bearing?
Last edited by Technocrat : 19th February 2010 at 20:52. Reason: Please avoid un-necessary bolding of text, thanks
budrukkar is offline   Reply With Quote
Old 19th February 2010, 23:33   #7
Thanked: 116 Times
Most probably, your clutch plate is worn out.
Utopian is offline   Reply With Quote
Old 20th February 2010, 19:45   #8
Thanked: 103,475 Times
Originally Posted by budrukkar View Post
My problem is that engine rpm rises quickly but not speed respectively.Is it problem in clutch?Is it best solution to replace clutch and clutch release bearing?
100% a worn out clutch. Best for you to replace it before your car breaks down.
Problem with pickup in Baleno Sang Technical Stuff 24 11th September 2016 11:08
Palio 1.2NV - 48000 kms - PickUp problem after oil seal change arijit Technical Stuff 2 8th March 2010 13:33
Safari Pickup problem beyond Keylong rkbharat Technical Stuff 30 10th June 2008 12:19
Santro Xing 03 - Pickup Problem vkochar Technical Stuff 14 30th May 2008 17:25
Loss in Pickup - 2004 MPFi Zen skydiver Technical Stuff 9 29th February 2008 14:10
