Old 19th December 2014, 12:23   #16
joybhowmik's Avatar
Thanked: 1,928 Times
Default Re: Issue with Santro Zip Plus
Originally Posted by pavan_6818 View Post
Can anyone explain what the issue was? Is it something wrong with my ECU?
You say you 'feel' the RPM increase. The Santro Zip Plus does not have a tachometer.
How do you know for sure it's the engine rpm that increases when you switch on the AC?
And if you say it's the engine hum that increased - that noise could be due to other reasons - as well.
joybhowmik is online now   Reply With Quote
Old 19th December 2014, 13:15   #17
pavan_6818's Avatar
You are right, My car doesn't have tachometer. I could hear the increased engine sound when I switch on the AC and when switch off it becomes normal.
Can you explain me what other noise it could be, may be I can check in that aspects.
pavan_6818 is offline   Reply With Quote
Old 19th December 2014, 14:08   #18
You could look at the accelerator cable or its mounting point on the throttle body of the car. I had a similar occurrence with my car. Even with the cluth depressed and the foot off the accelerator cable, the RPM of the car used to increase.
Turned out that the accelerator cable mounting was loose leading to a play in its movement.
indianv2 is offline   Reply With Quote
Old 19th December 2014, 15:11   #19
joybhowmik's Avatar
An easier way would be to get an OBD Scan done.
Old 23rd December 2014, 20:59   #20
Thanked: 130 Times
Need help ?????
Unlikely. Engine idle RPM goes up with AC compressor switching on. Too high an increase may be due to a bad IAC unit. Get a mechanic to check the car and if needed open and clean the throttle body.
fighterace is offline   Reply With Quote
2 problems with Santro Zip plus!!! loving_alaap Technical Stuff 2 27th April 2009 18:12
Santro Zip Plus LS 2002 - 74,000kms review suren181 Long-Term Ownership Reviews 29 17th July 2008 18:21
Urgently Wanted Santro GS Zip Plus BUSA Shifting gears 0 3rd September 2006 17:22
Width of Santro Zip Plus psynaps3 Hatchbacks 4 15th April 2006 23:14
