Old 28th November 2009, 07:58   #1
Default Clutch vibration in new i10
Hi guys,
Took delivery of a new i10 magna yesterday for the wife. While driving home, I felt that there was some significant vibration coming from the clutch during driving. The vibration was there after every gear change and after the clutch was completely released. That is.. say I would be driving and if I touched the clutch with my foot it would be vibrating. Pressing the clutch down ever so slightly.. (maybe 1/2 cm) would stop the vibration.
Does anyone know what the problem is? Should I take it in to get checked? Awfully annoying to have a problem in a new car!
Thanks in advance!
AntibiotiX is offline   Reply With Quote
Old 1st December 2009, 16:58   #2
svaid's Avatar
Do get you car checked ASAP. Unless you were under-revving, I don't expect any noticeable vibrations on the clutch pedal
svaid is offline   Reply With Quote
Old 1st December 2009, 17:03   #3
shishir_bn's Avatar
Thanked: 108 Times
This might be due to the nuts getting loosened. take to the A.S.S and they will tighten it and it will be fine. IMO the nut and bolt which holds the clutch pedal is lose
shishir_bn is offline   Reply With Quote
Vibration in Hyundai i10 sidd25 Technical Stuff 7 15th January 2010 23:27
Clutch replaced but still having vibration problem prasannapatil Technical Stuff 13 12th May 2009 11:27
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
