Thread Tools
Old 11th August 2005, 22:18   #1 (permalink)
chittibells2005's Avatar
Default skoda rs question
today one of my freinds with a lisence wanted to test drive and rs so we wend to jmd skoda in new bombay and he drove it while i was in the back seat and the salesman told him all the features and during the second half of the drive the salesman took the wheel and he showed us the features of this car. at one point he was talking about traffic jams and i notice him releasing the clutch without touching the accelerator and i was bracing myself for a sudden jerk and the engine would stop but to my surprise the car just creeped forward like and auto tranny does when not on the brakes and in drive. for me the hardest part of driving a car(never driven a manual trannyed car this is based on experience with motorcycles) is to get it rolling in first gear so i would stall the engine several times before moving so a feature like this really helps to get the car moving. how is this done can this be added to any other car.
chittibells2005 is offline   Reply With Quote
Old 11th August 2005, 22:25   #2 (permalink)
karthik247's Avatar
Infractions: 0/3 (12)
All the cars pretty much move in half clutch, ie. relese the clutch, not fully but 3/4th or so..
__________________
Driving around... ON BOOST!!!!!!!
karthik247 is offline   Reply With Quote
Old 11th August 2005, 22:38   #3 (permalink)
turbo_lover's Avatar
all cars roll in 1st and 2nd with neither the clutch nor the throttle applied dude ..
..if u gently release the clutch the car will roll in 1st or 2nd ..
__________________
Every weapon needs a master
turbo_lover is offline   Reply With Quote
Old 11th August 2005, 23:03   #4 (permalink)
satan_crazy's Avatar
i didn't know this! never noticed it either ...
__________________
Lucifer waits for everyone
satan_crazy is offline   Reply With Quote
Old 11th August 2005, 23:04   #5 (permalink)
sorry i have no clue about manuals transmission cars thanks for enlightening me does this happen in all gears or just 1 and 2 like u mentioned because he said the car will go up to 1000rpm in all gears.
Old 11th August 2005, 23:57   #6 (permalink)
1000rpm is the idling engine speed ..you will notice the car actually pulling a roll in 1st and 2nd ...higher gears its minimal hence not very noticable because they dont have enough power to pull at speed below 10kmph ..
__________________
Old 12th August 2005, 09:41   #7 (permalink)
adya33's Avatar
is that because of the gear ratios?
adya33 is offline   Reply With Quote
Old 12th August 2005, 10:49   #8 (permalink)
yes ..all about the gear ratios..
higher gears deliver lesser power..because at those gears the car is already moviing he nce dont need as much force to drive the wheels..
__________________
Old 12th August 2005, 11:41   #9 (permalink)
sridhar24's Avatar
As per my experience i found it easier to move a diesel car than a petrol car without pressing the throttle, correct me if iam wrong. I found it easier to do so in Qualis.
__________________
Don't limit your CHALLENGES, challenge your LIMITS!
sridhar24 is offline   Reply With Quote
Old 12th August 2005, 12:28   #10 (permalink)
Psycho's Avatar
Well most european cars idle at a slightly higher rpm to allow for crawling at blockages on roads as Turbo lover said the higher idle rpm in the low gears (1 and 2) allows the car to inch forward without having to press the accelerator, the car does not generate enough torque on the higher gears to get the car to move forward.
__________________
Learning is a continuos job that keeps me busy.
Old 12th August 2005, 13:04   #11 (permalink)
Surprise's Avatar
The tutor at the driving class will never allow the learner to touch the accelerator pedal for 1st gear. That way I came to know about this. He has got a Santro for training.
But once you used to the driving, we don't have patience using this method.
Surprise is offline   Reply With Quote
Old 12th August 2005, 14:47   #12 (permalink)
tsk1979's Avatar
Diesels have higher low end torque compared to petrol, so you will find zero throttle(idling speed) roll ons easier.
__________________
Reclaiming.....!
Old 12th August 2005, 16:57   #13 (permalink)
greatDrive's Avatar
I never use gas padle in traffic jams when I am in first gear, I just mkae use of my clutch. But one has to be very careful while releasing the clutch, it should be very slow and steady.
My Car's rpm at idling remains between 500 to 1000. I am talking about Petra Petrol.
B
greatDrive is offline   Reply With Quote
Old 13th August 2005, 18:07   #14 (permalink)
ananthkamath's Avatar
Its all about synchronization and clutch 'feel'...I have rolled my Indica in all the gears except 5th on a perfectly flat road from standstill...Its possible..Even then I feel the low-end on the Indica is not as good as some of the newer engines...It may be due to gear ratios also...
Ananth
ananthkamath is offline   Reply With Quote
Old 13th August 2005, 18:38   #15 (permalink)
Where do you draw a line between excessive usage of the clutch and appropriate usage of the clutch?
Assume that you are the first guy at the red-light, and when the light turns green, you have two options - use the clutch for crawling, or use the accelator and release the clutch asap. In the latter case, don't you feel that the clutch would've been used a little sparingly??
__________________
Thread Tools
Skoda Fabia 1.2 ICE Question abhinav.gupta88 Ask the Gurus 1 23rd June 2008 12:08
HU Question blue2ki Product Discussions 7 20th January 2008 00:02
Civic VS Skoda Rider VS Skoda Tdi X-Machine Sedans 20 7th August 2007 18:28
Skoda diesel vs Skoda automatic ?? khaadu75 Sedans 20 5th January 2006 21:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
