Thread Tools
Old 16th August 2005, 10:13   #16 (permalink)
Originally Posted by Revvhead
Puff,
the wheel sound problem dropping into potholes seems unfortunately very common, and it is a very harsh sound.
Anyway, go to your dealer and insist its a Suspension prob
it cant be the wheels coz the VXi comes with 14" rims iirc
Tell him firmly, that you have checked and its a common problem,
have him check the front Lower arms for tightness and go thru the thread link posted abv
as for the platic, nab yr dealer
Do not run yr lamps without relays, you will put excessive drain on your battery
No, the Vxi too comes with 13" wheels.
Which thread link?
See, I'm forbidden to put relays. Will putting 100/90w bulbs really affect the battery or just the fuses blowing as the accessories shop guy predicted?So, do i go back to the 55/60watt bulbs?
Puffdamgcdragon is online now   Reply With Quote
Old 16th August 2005, 12:40   #17 (permalink)
Originally Posted by nimish
Puffdamgcdragon@ the most easiest and reliable way to find the month of mfg of ur vehicle is the SEAT BELT.......
go grab your seat belt and go right upto the bottom where you find a white tag. ....this will display the details.....you can get fair idea from this tiny tag....
Thanks Nimish,
Just rushed down and checked the Seat Belt. It says manufactured in May 2005. (Phew!) But the chasis says either July 05 or Jan 2003 (whichever way U interpret the Chasis number- MA3EEJ91500 120155x G5. Wonder if I can be really sure??
@ Samurai- Ok, I just called up the Hindalco office at Calcutta whre the alloys were ordered from. Spoke with a Mr. Biplap Sen who is the Manager, Aura wheels. Helpful chap- He confirmed that the series E01445 which I have on my car has the offset ratio of 35. PDC 100 and size 14x5.5J, so it should match the Baleno fine.
What do U think? Does it have to be 6J/ 38 offset?
Old 16th August 2005, 12:58   #18 (permalink)
Hey, sorry to drag this topic furthur, Had my manager check all the seatbelts- the front two and one of the rear ones read 20/ 04/ 2005 and one of the rear ones read 01/07/05. booked the vehicle in end July. Anything fishy here?
What about the chasis Number? Is it July 05 (G5)or do I read the first 2 numbers in the plaque after M, which says A3? ( The extended chasis number with the G5 is not on the plaque under the bonnet along with the Engine No. It is engraved saperately on the chasis itself, hidden behind a big cable/wire.
I know am being a bit of a bore, but can U guys reassure my fears?
Will take the suspension and other problems step by step.
Old 16th August 2005, 14:18   #19 (permalink)
merve_extreme's Avatar
the car has been manufactured not before 1/7/05.those old dates on other belts means those belts are from the previous seatbelt purchase or consignment that maruti ordered.
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 16th August 2005, 14:27   #20 (permalink)
Hi, I checked under the bonnet and there's a Plaque with the chasis no- MA3EEJ91500 120155
and below it there's Engine No. G16BBN 514238
A little furthur away, engraved on the chasis itself, the same Chasis number is again there with the addition of xG5 in the end. Now, according to U, my car's either ofthe Jan 2003 stock (MA3) or July2005 (G5). If it is July 2005, then there's nothing wrong as I booked the car in End July. Which one is it?
It is G5 indeed. MA3 is the model series. I made a mistake.
BTW, also checked out through sources (the serial # suggests) it came out of production shop in the week starting 11 July. So it's pretty much OK.
indrajitr is offline   Reply With Quote
Old 16th August 2005, 14:32   #21 (permalink)
You have to put a relay. And Maruti guys should be able to do that. Articulate them a bit strongly and see where it goes
Old 16th August 2005, 14:36   #22 (permalink)
Old 16th August 2005, 14:47   #23 (permalink)
Samurai's Avatar
That would have been perfect, but 5.5J is acceptable in the absence of 6J. The offset of 35 should be fine.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 16th August 2005, 17:46   #24 (permalink)
The front sound u mentioned was traced in my baleno to the power steering hose and it is going to be replaced by a modified hose by the MUL dealer under warranty.
I have shod my car with 195/60/14R Michellin Certis, A 6j rim is more appropriate hthan5.5j.
this is not however the cause for ur problem.These fat tyres are fixed on their Demo vehicles by both the MUL dealers in Coimbatore. Dont worry can contact MUL via their site and they do
promptly respond.
wildcard is offline   Reply With Quote
Old 16th August 2005, 20:14   #25 (permalink)
After going through this thread I have gone through the RC Book of my Baleno which shows the date of manufature as Jan 2005 . I took the delivery only on 30th June 2005.
Since the production month is Jan 05 I do not know whether my vehicle is BS2 or BS3 ....
Do you guys think I should contact MUL ???
Santhosh
Sachin is offline   Reply With Quote
Old 16th August 2005, 20:45   #26 (permalink)
As I understand, headlight beam adjustor is only on BS-III models. So, just check and ensure that it has one.
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 17th August 2005, 03:17   #27 (permalink)
Puff,
I really dont think that one should be doing high speed over potholes more than a couple of inches deep...the Baleno is simply not build for that kind of drive....
I am just back from a 1600 km trip (hyd-mumbai-hyd) and I also have had to slow down wherever rain had washed away the road...
Some other car may take the abuse without whine...but all of them will have issues in long term if you abuse them ovver rough terrain.
100/90 may fade your reflector in the long term...as there will be excessive heat generation
Buffetfan is offline   Reply With Quote
Old 17th August 2005, 07:13   #28 (permalink)
Yes . I have the headlight adjustment...so that means mine is a BS III.
But don't you think that I should get a new car instead of a half an year old car ....I request the fellow BMPians for the valuable input.
Old 17th August 2005, 10:20   #29 (permalink)
Thanks a ton, all of U guys. Indrajit, Samurai, Rudra, Nimish, Revvhead and all of the others- Ur valuable inputs have been most highly appreciated, guys. ( This sounds like an acceptance speech for an Oscar! )
I've worried and fretted over the condition of my new car for the past several days and now I guess I'm pretty well equipped to handle the Maruti dealer if they say that the warranty on my suspension is void.
But, in retrospect, I should have stuck to 13" wheels and just put alloys and broader tubeless. Looking at the condition of the roads around these parts, It's highly unlikely that i'll ever do more than 100-120, that too on the plains and I'd have the confidence to throw the car at the dealer's face when all of these suspension problems cropped up, instead of worrying and preparing for the worst case scenario....
I've done about 500 Kms in the past week and next week or so when I go down to Siliguri for my first servicing, will handle the dealer. Am keeping my fingers crossed that he dosen't blame the wheels upgrade for all of the suspension problems and just fixes the damn thing.
If worst comes to worst and he doesn't believe me or all of the sites/ posts i show, what can I do? any ideas, guys???
Oh and one more thing- Since I'm forbidden to put a headlight relay do I carry on with the 100/90 bulbs or revert back to the original 55/60 watts? Any real damage possibilities apart from the fuses blowing and long term headlight casings going dull?
Old 17th August 2005, 11:17   #30 (permalink)
Revvhead's Avatar
Dude, considering the area where you live (been there)
good lighting is a must,
Stick to the 100/90's and install a relay
else install a good set of driving lights!
__________________
The Swift DZire has a 6 Month waiting period to give you time to seriously reconsider buying something that Ugly
Revvhead is offline   Reply With Quote
Thread Tools
Baleno Problems shivshanker Technical Stuff 56 9th June 2008 22:43
Brand new Baleno for 4 lakhs !!!! shobhit15 The Indian Car Scene!! 21 30th August 2007 09:11
Baleno add-on blues- problems of a nomadic existence Puffdamgcdragon Modifications & Accessories 10 30th July 2005 02:55
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
