Old 3rd December 2009, 14:14   #1
Default Rudimentary methods of cleaning car radiators
Hello all
Can you all help in listing out the best methods of cleaning a car radiator with out having to remove it from the car itself.
bsa1955 is offline   Reply With Quote
Old 3rd December 2009, 14:21   #2
sumeethaldankar's Avatar
Thanked: 1,158 Times
Originally Posted by bsa1955 View Post
Hello all
Get it flushed from the service centre.
sumeethaldankar is online now   Reply With Quote
Old 4th December 2009, 00:27   #3
IndrojitSircar's Avatar
Thanked: 116 Times
Just open the readiator hose at the bottom of the raditor and allow all the coolant to drain out.Then you can flush it with distilled water and then refit the hose back and fill up the radiator with coolant and distilled water mixture.Also remember to clean out the reserve tank as well.
Old 5th December 2009, 15:25   #4
Rehaan's Avatar
Thanked: 25,038 Times
This will flush just the radiator, but not all the coolant passages in the engine (ie the entire cooling system - recommended).
bsa1955, pretty much any radiator-flush fluid you buy will have detailed instructions on the package.
Which one is the best? I'm not sure -- but we have many threads on this. Please do search.
cya
R
Old 5th December 2009, 15:56   #5
Thanked: 152 Times
My experience is once car has run started showing heating issues , AC insufficient cooling in spite of fine AC it is best to get a new radiator . Cleaning is too difficult as the fins are too marrow.Though some mechanics open the radiator jacket and use a wire to clean the pipes .The issue here is we loose the pressure bearing capability of jacket as it is no where the OEM specs now .Other methods like using chemicals can never restore your radiator to new condition.
Trust_In_Thrust is offline   Reply With Quote
All about car dent repair & painting - Processes, methods & tools joybhowmik Technical Stuff 108 9th September 2017 00:07
Radiators - Lawrence Radiators (Mumbai) GTO Mumbai 1 22nd December 2013 00:24
A very rudimentary question about the usage of new car nitin.dangayach Technical Stuff 1 23rd August 2008 17:19
