Closed Thread
Old 9th December 2009, 14:26   #16
finneyp's Avatar
Thanked: 175 Times
I am surprised that even Fiat engineers are unable to diagnose the cause of abnormal treadwear!
If they are unable the fix the issue, they should have replaced Sachin's defective car with a new one.
Pawan, can you ask Sachin to join this forum, so that we can get more details from him.
finneyp is offline
Old 9th December 2009, 14:30   #17
Thanked: 105 Times
I sent him the this post's link to Sachin, I will ask him to join this forum and reply back the queries.
pawan_pullarwar is offline
Old 9th December 2009, 14:32   #18
sdp1975's Avatar
Thanked: 972 Times
I've been following this thread on other forums. Fiat should replace the defective vehicle.
Even after so many visits to the factory and the traumatic experience of the owner if the problem does not get rectified, Fiat should replace the vehicle accepting fault with the vehicle.
sdp1975 is offline
Old 9th December 2009, 14:36   #19
hiren959's Avatar
Thanked: 51 Times
In this case Sachin must have to file a case in consumer court and ask the money of Merc S Class.
hiren959 is offline
Old 9th December 2009, 14:40   #20
Sachin,
Seriously, how pronounced is this issue ? Or is it just psychological ? I am surprised that FIAT can't handle such a minor issue. I had wheel alignment issues with my car too but they resolved it in no time. The drag is gone now. Would like to know if you are being extremely sensitive to this issue ? I am no FIAT representative but this is very interesting to hear.
rganeshiyer is offline
Old 9th December 2009, 14:44   #21
Thanked: 29 Times
From the pictures, can't really tell the pattern of the wear. But if I look at the bottom last picture, second column, it looks like there is a wear from inner edge of the tyre towards the center (feather edge). If that is correct, then it seems to be a toe in issue which will also explain the car being dragged to one side and hence the pattern.
However, since I can't really tell from the pictures, if only the inner edge is worn, it could be the camber issue and the car is riding on its inner edge more than the rest of the contact surface.
Seeler_Rebeiro is offline
Old 9th December 2009, 14:46   #22
McLaren Rulez's Avatar
Thanked: 591 Times
What work did Fiat do on the car so far? I'm sure stuff like wheel alignment, balancing, toe-in etc would have been checked.
McLaren Rulez is offline
Old 9th December 2009, 14:47   #23
Thanked: 29 Times
If FIAT did indeed look at the car.
Old 9th December 2009, 14:51   #24
wildon's Avatar
Thanked: 1,061 Times
As per him FIAT didn't disclosed the details of works done on his vehicle.
wildon is offline
Old 9th December 2009, 14:52   #25
.anshuman's Avatar
Thanked: 9,159 Times
I think this issue is related to some suspension problem, Did the service center tell your friend the reason for this and What was done to the car?
After all this has been done the only way left is to approach consumer court.
.anshuman is offline
Old 9th December 2009, 15:01   #26
AnonymousCoward's Avatar
Seems like a lemon to me
Are there any other Punto's driven to his office location? Tyre wear of that car will confirm if Sachin's car is a lemon.
As suggested by some, it is better to take it up with higher-ups in FIAT (if not done already) and ask for replacement. Go to court if they do not acknowledge the problem.
AnonymousCoward is offline
Old 9th December 2009, 15:02   #27
samsan02's Avatar
Thanked: 17 Times
Can n't make out much from the pics, can someone post them again in vertical view.
Do all four tires have the same pattern or is it the two left ones?
Are you sure that the vehicle did visit Fiat plant or you are going by the words of the dealer?
samsan02 is offline
Old 9th December 2009, 15:08   #28
Thanked: 29 Times
Suspension issue will result in camber going off, whcih should have been detected by the service center and which is why I suspect they have not done a proper job. Has your friend visited any independent wheel alignment/balancing shop ?
Old 9th December 2009, 15:46   #29
Thanked: 13 Times
While the entire issue is unfortunate and ugly, I feel there are some good things as well like replacing tires free of cost, not denying the problem and taking it for inspections etc. Maybe, my mindset is set very low after reading harishv's issues with skoda jmathew(?) with peninsular Honda.
RakishRam is offline
Old 9th December 2009, 16:35   #30
Well these incidents really tarnish the image of a otherwise good products.
My Uncle (Govt employee) who wanted to buy a hatchback was really keen on Punto.But his office mate who owns a Punto told him to look for some other options as his Punto was giving a FE of 12 which he considered low .
Today he called me & told he had zeroed on swift VXI,reason Being a complete novice in terms of cars he dint wanted to take any chance with FIAT,Indica Vista was his other choice.
Goes to show few members like us have access to reviews/reports available to decide upon any model what about the mass junta which constitutes the 95% of the sales pie? They just rely on the advice available from the near by mechanic,or the freinds who have almost nil knowledge of cars.If they come to know this kind of one off instance,will cite it for life time scaring away potential buyers.
kratos11 is offline
Closed Thread
Italiano Bellezza - Fiat Grande Punto 1.3 MJD Emotion. EDIT : 2nd Service update DRIV3R Test-Drives & Initial Ownership Reports 71 12th January 2014 23:24
Protest against Tata Motors.EDIT Supreme Court Orders Tata to repair Sumo (pg.40) v1p3r The Indian Car Scene 713 19th January 2013 18:31
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Exchanged Swift with Grande Punto EDIT: 15000 kms update .anshuman Test-Drives & Initial Ownership Reports 321 7th July 2010 18:10
Iceberg is home (Fiat Grande Punto) Update: 9000 kms in 4 months kailashnj Test-Drives & Initial Ownership Reports 50 29th May 2010 12:33
