| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) | ||
| Senior - BHPian | Quote:
p.s- mods, please delete post#12.... a double post, by mistake...
__________________ DAD | ||
| | #17 (permalink) |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| All gas filled dampers have oil in them. It is the oil that damps the oscillations of the suspension mass. Gas cannot do the same on its own though theoretically all fluids can do the damping. Remember that all gases are also fluids. Nitrogen is added as gas to prevent foaming of the oil in gas filled dampers to improve effeciency of the dampers. Chance of failure in gas filled dampers is slightly higher. Please follow the links if you wish to know more or type gas dampers in google or yahoo search. http://www.eu.tenneco-automotive.com.../gas_shock.htm http://www.tirerack.com/suspension/t...o_sport_rd.jsp I hope these links clear the confusion of gas filled dampers. Bye and wear your seatbelts. Last edited by drpullockaran : 21st August 2005 at 07:39. |
| | #18 (permalink) |
| BHPian Join Date: Jul 2005 Location: Delhi
| Well I guess now I know the difference between gas charged and oil filled shock absorbers. However the problem still remains that the ride quality (this can be due to tyres) is on the harsher side specially on the rear. I have a year old Esteem and the difference between the ride quality is substancial. It almost gives me like Santro like feeling where the car just bumps and rattles on bad roads. The reason I am concerned is not that I travel on bad roads, as most of my daily journey the problem is not even there thanks to the good delhi roads. However the reason I am concerned is that I like to travel a lot to Manali, Jim Corbet, Jaipur, Agra, Shimla and Chandigarh etc. I make a minimum of 2 trips every month. Now I am concerned that all states dont have good roads, and if the ride cant improve I would have to go in my esteem... :( So maybe I was wrong if I said I wanted to change the oil dampers to gas charged absorbers, as this seems to be a herculean task. So my question now is what are known tried and tested ways to improve the car ride from harsher to a smoother ride, like changing tyre pressure etc. |
| | #19 (permalink) | |
| BHPian | Quote:
If the 800 ones work, good for Aseem. I'm just saying that the chances of them working are not that high. Dampers go with the springs they were designed for. For example, the leaf-sprung 800 has different dampers to the coil-sprung one, and I'm not talking just about the mountings. | |
| | #20 (permalink) | |
| BHPian | Quote:
I don't know about the condition of roads in the places you mentioned, but if it doesn't involve high speeds then you can definitely try lowering the tyre pressure. It works. Or, if you want a simple non-technical solution which has worked for me, use sand bags in the boot. I know, its insanely crude, but it sure as hell works. Ananth | |
| | #21 (permalink) |
| Team-BHP Support ![]() | Maruti 800 is seriously underdamped. Anyone whose driven an 800 on our wavy country roads know how it bounces up and down like a pogo stick
__________________ The difference between the men and the boys....................is the speed of their toys. |
| | #22 (permalink) | |
| BHPian | guys, why is it that premium hatchbacks donot have independent suspension,inspite of them being called Premium ??? Quote:
| | #23 (permalink) | |
| | #24 (permalink) |
| Having an independent suspension at the back is not the holy grail to having a good ride at the back. My junk trap indica has independent setup at the rear and my Palio GTX has torsion beam setup at the rear. The Indica with new shock absorbers does not even come remotely close to the Palio GTX in terms of ride quality let alone compare it to the normal Palio 1.2 which is slightly softly sprung in comparison to the GTX. You have to design the suspension from ground up taking into cosideration the unsprung mass and also the total loading of the the rear suspension. You have to choose between harsh ride on smooth roads (which will generally give you a well damped ride on rough undulating roads) and floating ride like the Maruti 800 on smooth roads( which will thow you around on rough undulating roads). Bye and wear your seatbelts |
| | #25 (permalink) |
| BHPian | Yes I do agree that a badly setup independent does no better or is even worse than a beam axle. However the problem with the Indica is not one of high unsprung mass but a large spring rating. If you have 3 people in the back, the balance and grip of the car changes totally. The single rate spring used there is a compromise for cost purposes. A progressive at the back would do wonders for the Indica's ride. |
| | #26 (permalink) |
| Team-BHP Support ![]() | Indica V1 was a pure trailing arm and the geometry was flawed for both ride and handling. The V2 has a strut with tri-link arrangement. Supposed to be a vast improvement over the V1.
| | #27 (permalink) | ||
| BHPian | Quote:
| Thread Tools | |
Similar Threads | ||||
| Koni shock absorbers | razor4077 | Technical Stuff | 32 | 12th June 2008 23:14 |
| Shock Absorbers Replacement | AshOnTheRocks | Modifications & Accessories | 4 | 3rd April 2008 10:58 |
| Are the Gas Shock Absorbers really superior in absorbing bumps ? | mithun | Technical Stuff | 8 | 17th August 2006 10:40 |
| gas filled shock absorbers | Ironmarine | Technical Stuff | 1 | 24th July 2006 13:38 |
| Shock absorbers n suspensions | gbpscars | Modifications & Accessories | 1 | 10th May 2006 14:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
