Old 14th December 2009, 23:40   #16
dushmish's Avatar
Thanked: 76 Times
CCN, please refer to the manual supplied with the car. It will explain you the various settings and the do's and don't's. It is a common problem you are facing. Am sure you will find a solution there. Most of us do not know how to use the vent controls. If the problem persists, Please PM me, I will be glad to assist.
Ciao!
dushmish is offline   Reply With Quote
Old 14th December 2009, 23:45   #17
Doest matter it causes the headache or not, I just cant drive/survive without a car heater in the severe weather conditions that we have here now. It was -48C with the wind chill few days ago and today its -31C.
NullRock is offline   Reply With Quote
Old 15th December 2009, 09:06   #18
Default Tips used
Thanks everybody for the tips. I hadn't encountered this headache problem while using heating in the US mid west during winter, hence was curious to see how to solve this problem here in Bangalore. I tried these tips and found some relief:
- Car AC on so that there is no sticky feeling or sweating in the palms while driving (also helps in not getting fogged during rain)
- Outside air mode; I take in some pollution, but it goes away fast since outside air keeps coming in and going out ==> seems to make a big difference
- Car fan on level 1
- Heater on at the lowest level that is comfortable
- Car fan set to deflect the air to both face and feet so that whether it is hot air or cold air, it doesn't blow too much on the face
Before trying these, I kept the car windows on last week-end, kept the heating to maximum, and kept the engine on for 15-20 minutes so that any dirt in the vents go away / any bacteria etc. get taken care of. The slight bad smell in the car went away with this.
Thanks,
ccn
ccnarayanan is offline   Reply With Quote
Old 10th August 2015, 12:33   #19
Default Re: Car heater causes headache
My 2010 model WagonR LXi has suddenly developed a snag in AC. While the cool setting (blue) work well, the heat setting (red) also gives out cool air.
Seniors, any help? Will friendly neighbourhood workmen do justice to the issue? Thanks in advance.
Petropolitan is offline   Reply With Quote
Old 10th August 2015, 12:48   #20
SunnyBoi's Avatar
Thanked: 2,832 Times
There will be a valve which allows warm coolant to flow through a heater core in the HVAC Unit and thus generate warm air.
In your case, the valve must be jammed, get the car to an AC expert, he should be able to open and clean the valve. Worst case scenario, replace the valve.
SunnyBoi is offline   (1) Thanks Reply With Quote
Old 10th August 2015, 13:11   #21
Eddy's Avatar
Thanked: 5,067 Times
I am quite sure that this place will fix it for you at not so exorbitant prices, provided the location suits you.
http://www.team-bhp.com/forum/delhi-...den-delhi.html (Virk Auto Electric Works - Raja Garden (Delhi))
PS: Friday closed.
Eddy is offline   (1) Thanks Reply With Quote
Old 10th August 2015, 13:31   #22
ssambyal1980's Avatar
Thanked: 1,062 Times
Also had similar experience in the past. I guess this problem is not car specific but rather is experienced by most users, irrespective of the make of the car. Most of the people with whom I have discussed this issue have reported feeling nauseated along with heaviness in the head.
As a remedial measure, one should always keep the air vent open when the heater is on , so that the outside fresh air flows into the cabin (this is what the car manufactures suggest in the manual) and the heating should be set to lukewarm levels.
ssambyal1980 is offline   Reply With Quote
Old 10th August 2015, 13:58   #23
gautamkhadse's Avatar
Thanked: 172 Times
As someone rightly pointed out , the hot air is dry and that makes the cabin really really dry . So keep the rear windows , slightly lowered and also keep the recirculation mode OFF . Let the car suck in some fresh air .
I used to have similar problem . So i started directing the hot air toward the legs . That way the cabin warms up gradually . When it starts getting hot and dry open the windows for a moment . Let some fresh air IN and then start the heater again . See if it helps .
gautamkhadse is offline   Reply With Quote
Old 10th August 2015, 14:19   #24
Manufacturers also suggest that the warm airflow should be directed towards the windscreen. That would spare it from getting fogged up, hence would ensure clear line of sight ahead.
Continental Tyres are a headache ! Garipagol Tyre & Alloy wheel Section 19 28th December 2011 15:36
12v car water heater gypsyFreak Modifications & Accessories 2 14th December 2009 12:02
Why can't we shut the heater off? santosh.s Technical Stuff 58 23rd March 2009 14:06
Does heater consume engine power? DCEite Technical Stuff 21 5th January 2006 00:28
