Old 23rd December 2009, 17:18   #16
vdiatech's Avatar
as a cheaper solution, you could try getting the idle control valve cleaned, remove it from throttle body and use the throttle body or carb cleaner spray and a very soft cloth
if it does not help, then order from outside india
vdiatech is offline   Reply With Quote
Old 24th December 2009, 10:48   #17
wildchild4lyfe's Avatar
yes...i shall try it today..Thanks!
wildchild4lyfe is offline   Reply With Quote
Old 28th December 2009, 11:12   #18
ok finally after scanning the car and getting the injectors the TB etc etc etc cleaned and frustrated..!!..finally it just struck me that maybe i should just take the battery cables off and put it back on.. nothing to loose anyways..ET VOILLA!! SHE LIVES!!!
all i could do is laugh at the whole episode..!!
Engine Stalling Problem rkkoul Technical Stuff 35 5th May 2016 13:30
Volvo recalling 7,000 diesel cars (including S60 & XC60) for engine stalling problem cbatrody The International Automotive Scene 0 21st February 2016 19:59
Engine stalling at low revs / idle kaushik_s Technical Stuff 37 4th March 2014 16:24
Santro LPG - Engine Stalling in 2nd & 3rd Gear Foxbat Technical Stuff 5 31st December 2012 07:45
Engine stalling at low speeds in my Fiat Grande Punto 1.2 E motor spirit Technical Stuff 20 7th February 2011 19:43
