Old 27th January 2014, 22:34   #61
Deeps's Avatar
Thanked: 68 Times
Default Re: Starting the Engine in Snow / Cold Areas
My learned fellows. Is this something that will solve the purpose?
http://www.snapdeal.com/product/abro...os=17;32#prdsc
Deeps is offline   Reply With Quote
Old 28th January 2014, 00:28   #62
tsk1979's Avatar
Thanked: 16,422 Times
Good find. Yes it should help.
However, even if you use such a product, make sure you cover warm engine with a tarp, esp if you are expecting -10 kind of temperatures.
Old 28th January 2014, 09:39   #63
Deeps's Avatar
Thanked: 68 Times
Thanks Tanveer. Yes, your tarp idea will also be implemented for sure. Better to play safe than be stranded.
Review: Glacier PLC 1144 Snow chains and SCC ZT729 Snow cables tsk1979 4x4 Technical 5 6th March 2014 10:45
Of cold mountains, and tonnes of snow tsk1979 Travelogues 138 8th June 2009 17:37
Cold starting with the new Indica NA sidharths84 Technical Stuff 6 3rd September 2007 17:38
Excess all areas: Rock's top 50 big spenders ajmat Shifting gears 4 16th June 2006 12:45
Dangerous areas - RAINY MUMBAI Surprise Shifting gears 0 1st August 2005 12:58
