Old 17th December 2009, 17:09   #16
sameer sultan's Avatar
Thanked: 232 Times
Originally Posted by amoghchaphalkar View Post
No "problem" as such. Just that they have a better designed part now and hence are replacing it. It is a proactive action by Fiat and not a reaction. The current design of the clutch slave cylinder "may" develop a leak.
thanks amogh. My Linea is due for 2nd service shortly. I shall get it replaced if my VIN number comes under the replacement criteria.
sameer sultan is offline   Reply With Quote
Old 17th December 2009, 17:17   #17
vinay.pillai's Avatar
Thanked: 13 Times
My car is done with the change. I am seeing a bit more zippiness when I accelerate from zero. It may be my perception but clutch is real smooth now.
vinay.pillai is offline   Reply With Quote
Old 18th December 2009, 15:54   #18
geeash's Avatar
Thanked: 129 Times
It is for punto also mate
geeash is offline   Reply With Quote
Old 18th December 2009, 16:13   #19
bnzjon's Avatar
Thanked: 124 Times
TASS has changed mine too.
I dont see any visible difference in either smoothness or zipiness. Maybe, i have not noticed the difference.
bnzjon is offline   Reply With Quote
Old 19th December 2009, 23:56   #20
firstguri's Avatar
Thanked: 295 Times
Yes, we had to get our CSC in the Linea changed as well. It was very well carried out by our TASS and I waited for only 2 hours.
firstguri is offline   Reply With Quote
Old 20th December 2009, 21:32   #21
Thanked: 921 Times
does this apply to petrol as well as diesel lineas?
Axe77 is offline   Reply With Quote
Old 20th December 2009, 22:02   #22
Sathya_sc's Avatar
Thanked: 641 Times
Had some issues in my rear suspension.. some noise.. When I took it to the service station.. my clutch slave cylinder was replaced..
Good job FIAT in replacing it proactively.. meanwhile the suspension sound from rear has also been rectified.
Sathya
Sathya_sc is offline   Reply With Quote
Old 20th December 2009, 22:57   #23
FastLove's Avatar
Thanked: 99 Times
I cannot paste the list. I had checked at my usual service station. I could see it because of the good relations I have with my service advisor. I suggest you go to your authorised service station and check the list they have.
That is contradictory!
If they have a "better designed part" now then why do they have only a particular list of Lineas to have the CSC replaced.
Mine is April 09 Linea and i havent got any intimation from TASS.
If this better designed part was available from a particular date, then FIAT would hace recalled all Lineas/ Puntos manufatured before a particular date. No list would have been required.
FastLove is offline   Reply With Quote
Old 21st December 2009, 02:46   #24
firstguri's Avatar
Thanked: 295 Times
Yes it applies to both the petrol and diesel versions. Tell you what, it even applies to Punto.
@FastLove
I dont think that its a defective part but something that Fiat thought needs improvement. Now I dont know how Fiat came out with the list. Maybe the newer batches are exempted, maybe, I dnt know. Our's is Jan' manufactured and my story is here:
http://www.team-bhp.com/forum/test-d...ml#post1621605 (F. Red Linea MJD Emotion through CSD)
And you get in touch with your TASS and get your VIN checked up. AFAIK our TASS (Hind Motors, Mohali) isn't calling up the cars but check the cars when they report to the service centre.
Old 21st December 2009, 04:30   #25
ph03n!x's Avatar
Thanked: 118 Times
Does anyone have a photo showing both the old and new CSC?
ph03n!x is offline   Reply With Quote
Old 21st December 2009, 07:10   #26
greenhorn's Avatar
Thanked: 1,309 Times
Clutch Slave Cylinder - Punto | Spares & Accessories | Car Forums - CarWale.com
here's a snap of the actual part that was replaced
Old 21st December 2009, 12:20   #27
aks_karthik's Avatar
Thanked: 215 Times
Hi all,
After replacing the CSS i have faced a small jerk while changing gear from 2nd to 3rd and some time there's no thrust after pressing gas pedal too.
Again,in any gear,Depress the clutch and release it without pressing Gas pedal while running i feel a jerk at the last.
Please check and let me know.
I don't know whether this is my perception or faulty CSS or not fitted properly.
I'll check it by this weekend most probably.
aks_karthik is online now   Reply With Quote
Old 21st December 2009, 13:45   #28
firstguri's Avatar
Thanked: 295 Times
Originally Posted by aks_karthik View Post
Hi all,
Well karthik even I expeience that slight jerk, but there is definitely a response from the engine when I press the acc' pedal.
Old 21st December 2009, 14:09   #29
srishiva's Avatar
Thanked: 814 Times
Do you really believe in the better designed part story? There should be a defect which they are trying to correct.
Maybe you should also 'pro-actively' call TASS and find out about your car !
srishiva is offline   Reply With Quote
Old 21st December 2009, 14:26   #30
Gallant's Avatar
Hi Everyone, I got my Punto's Clutch Slave cylinder replaced last month, when my car went to TASS for under boady coat. They hardly took 30 minutes to do so, so it's better we got it done in front of us.
I can feel the clutch is bit more smoother than before, but not any drastic changes.
I appreciate Fiat's proactiveness in replacing a part which they only suspect (read suspect) may cause problem in future.
Gallant is offline   Reply With Quote
Car with four cylinder engine or three cylinder engine? sunil8089 Technical Stuff 36 15th May 2017 19:54
USA: 46,000 Harley-Davidsons recalled over clutch fault Tushar Superbikes & Imports 0 27th April 2015 14:56
Punto frequent clutch slave cylinder problem ketan_kunde Technical Stuff 6 12th August 2013 13:54
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
