Old 17th December 2009, 17:13   #1
shiva_cool87's Avatar
Unhappy Indica Petrol - Not Starting!
Three mechanics have checked the car but they look clueless! My car has done around 25k kms and its around 4 yrs old.Could this be coz of a faulty starting sensor? How much would it cost? Any suggestions/help would be really great.!
shiva_cool87 is offline   Reply With Quote
Old 17th December 2009, 17:24   #2
manikjeet's Avatar
Thanked: 110 Times
have you got your car checked by a electrician tell him to see all the fuses as well as the main fuel pump fuse
manikjeet is offline   Reply With Quote
Old 17th December 2009, 17:26   #3
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
what exactly is the symptom? is it not cranking or cranking but not starting? only after knowing the exact symptom a comment can be made?
SPIKE ARRESTOR is offline   Reply With Quote
Old 17th December 2009, 17:27   #4
yeah,the electrician just checked my car.He was the one who suggested me to change the Starting Sensor.
Old 17th December 2009, 17:28   #5
manikjeet's Avatar
Thanked: 110 Times
then i suggest you take it to TASS
Old 17th December 2009, 17:28   #6
.anshuman's Avatar
Thanked: 9,159 Times
Please get the car checked at some competent workshop, The reasons can be anything from choked injectors, faulty fuel pump, ignition coil.......
Old 17th December 2009, 17:33   #7
I want to make sure that TASS doesn't loot me for what could be a small issue....!
Could it be a problem with the glow plugs?
Old 17th December 2009, 17:51   #8
.anshuman's Avatar
AFAIK Only the diesels come with glow plugs.
Old 17th December 2009, 22:39   #9
wanderernomad's Avatar
Thanked: 806 Times
Unless you tell us the exact problem you will have a virtual data bank of information as to what all can go wrong in the car. So guys please when ever you request suggestions on some issue please be very very specific. Its not like you make a vague statement simply as if to check if there are enough car nuts around.
wanderernomad is offline   Reply With Quote
Old 17th December 2009, 23:20   #10
dkamath's Avatar
Thanked: 120 Times
Does the "Check Engine" lamp glow within the instrument console? If the car can be cranked, then you could try activating the "limp mode" switch under the driver's seat. If it doesn't start even then, then sorry, no idea.
dkamath is offline   Reply With Quote
Old 18th December 2009, 02:59   #11
When I turn on the key,i see those red Battery,hand break indicators and when I try to start,the Check Engine indicator blinks.
Old 18th December 2009, 14:33   #12
Any inputs/suggestions/help ? Tomorrow the guys from TASS would be taking my car for a check up and I don't want 'em to swindle me....
Old 18th December 2009, 15:40   #13
Just below the driver's seat, you will find a tube like thing with a button on top - please try pressing the button and then cranking.
hrag is offline   Reply With Quote
Old 18th December 2009, 17:58   #14
Jaggu's Avatar
Thanked: 8,693 Times
Which car is this, what engine configuration does it run?
@hrag: are you referring to fuel cut off/reset switch?
Old 19th December 2009, 19:44   #15
@hrag - I did find that thing....but I dont see any button as such!
BTW its a Indica Lsi.
And also...thnx for the replies so far !
Starting problems Indica DLG vfmanuel Technical Stuff 19 14th December 2007 00:09
Cold starting with the new Indica NA sidharths84 Technical Stuff 6 3rd September 2007 17:38
Starting problem in INDICA... hianooo Technical Stuff 29 17th April 2007 18:15
Indica Turbo --Screeching sound while starting?? werfish Technical Stuff 8 4th March 2007 14:18
Palio not starting; ECU Check light not lighting up shineshine Technical Stuff 2 12th August 2006 11:50
