Old 19th December 2009, 15:49   #16
MCR
Thanked: 237 Times
Originally Posted by quattroa4 View Post
what you are saying MCR is good , but in forging you can not place parting line on the camshaft in diametrical axis .
as it is a longitudanal part , the parting line will come along the length ( axially) only.
Yes. The parting line will be along the axis of the shaft. Only then the grain will flow axially and the shaft can withstand the load.
@scuderiamania, I saw the pictures. The damage is because of shock load on the cam shaft. The damage makes this very evident.
MCR is offline   Reply With Quote
Old 20th December 2009, 18:14   #17
scuderiamania's Avatar
Thanked: 129 Times
Can you please explain what shock load is?
scuderiamania is offline   Reply With Quote
Old 20th December 2009, 22:51   #18
nitrous's Avatar
Thanked: 285 Times
I've only seen rockers being broken supposedly because of the camshaft.
Old 20th December 2009, 23:42   #19
SS-Traveller's Avatar
Thanked: 11,626 Times
Originally Posted by scuderiamania View Post
I saw both cams were broken. One was broken at two points and the other at one point.
Er... Is the Swift DDiS a twin-cam engine?
Edit: So it is!
Old 21st December 2009, 13:31   #20
quattroa4's Avatar
Thanked: 143 Times
as said by MCR its case of shear failure due to sudden impact load , migth be due to the valve itself . very possible . only thing is , should analyse the bearing which the pic is not showing . misalingment of the bearing with either its seat or camshaft must be checked.
quattroa4 is offline   Reply With Quote
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
Swift DDiS vs Ritz DDiS vs iKool ? anoovis Hatchbacks 1 21st October 2009 13:09
