Old 5th June 2010, 20:44   #16
sumeethaldankar's Avatar
Thanked: 1,160 Times
Default High idle a/c rpm for carb 800
My 800's (carb) idle rpm with the a/c shoots to 1300 rpm after start.I went to the a/c guy and asked him to set the idle lower at around 1000 rpm,it seemed fine afer he adjusted teh screw.However when i took the car out again in the afternoon i found the idle rpm had settled again at 1300.Is it advisable to to adjust the screw again or is this normal for a carb.
My driving distance was short around 3-5 kms but the temp guage was between the cold and the half way mark.So shall i adjust the idle screw again with a warm engine ?
sumeethaldankar is offline   Reply With Quote
Problem: High Idle RPM burnout_boy Technical Stuff 8 20th May 2016 16:19
Honda Stunner: High rpm on throttle input, engine not settling back to idle saket77 Motorbikes 10 2nd February 2015 12:33
Extremely High RPM at Idle after PCV Valve change abhipuru16 Technical Stuff 5 29th March 2012 11:01
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
