Old 4th February 2010, 18:08   #16
ElantraGT's Avatar
Nokia priority quoted me Rs.1100 for an original charger for E71 model. Are you sure you got the original charger?
ElantraGT is offline   Reply With Quote
Old 4th February 2010, 18:27   #17
sdp1975's Avatar
Thanked: 972 Times
Just to clarify, I got the original *car* charger at 199/- , MRP was 280/-
sdp1975 is offline   Reply With Quote
Old 14th February 2010, 19:25   #18
tanwaramit's Avatar
Thanked: 387 Times
IIRC, there is a 75W one fit for laptops which costs 850 bucks here in delhi.
where can I get it ? Hyundai ASC are selling it at 2400.
850 bucks is a steal.
tanwaramit is offline   Reply With Quote
Old 14th February 2010, 19:59   #19
Thanked: 49 Times
^^^ look at a car accessories shop or in Nehru place - The ASC prices are always astronomical.
CrackedHead is offline   Reply With Quote
Old 14th February 2010, 22:19   #20
vigsom's Avatar
Thanked: 603 Times
I fail to understand why we look at accessories at the ASC;there is such a choice available elsewhere
vigsom is online now   Reply With Quote
Old 15th February 2010, 01:00   #21
ghpk's Avatar
Thanked: 193 Times
Just to add some info for people who are using mobile and laptop in car, there's a Laptop charger available on Ebay.in which was shipped to me approx Rs.550/- works great with my compaq laptop.
Best thing about this was you don't need to carry the A.C. Laptop charger like you would do when u use car inverter.
This Laptop charger also comes with 8 Pins to fit most laptop.
I am using it since 2 week and its working great, only thing is your car must be running before it can charge a Laptop.
Old 15th February 2010, 07:10   #22
knp
Thanked: 18 Times
@ghpk, would you please give the link to this product at ebay.in? I am seeing many models and could not able to trace it down your product.
knp is offline   Reply With Quote
Old 17th February 2010, 10:48   #23
tanwaramit's Avatar
Thanked: 387 Times
+1 to this, need info on this, please share the link.
Also, ASCs are trusted for the brand they offer, else need to know a reliable shop, as I see majority of the shops are selling chinese stuff without any warranty.
Old 17th February 2010, 11:04   #24
ghpk's Avatar
Thanked: 193 Times
here's the link
must say"big.games.bazar. " proved to be a very prompt seller
Old 17th February 2010, 11:22   #25
sdp1975's Avatar
Thanked: 972 Times
What's the effect of the laptop charger on battery life, it will drain it right if used regularly ?
Old 17th February 2010, 14:10   #26
tanwaramit's Avatar
Thanked: 387 Times
which battery life ? Car ?
As long as car is running, there should be no problem, if the car ignition is switched off, then I guess there are some options like
1. Not to allow it to work
2. Allow it to work for some time before it is disconnected
3. Allow it to work till car battery is nearing drainage.
Old 19th February 2010, 03:16   #27
ghpk's Avatar
Thanked: 193 Times
If its your concern about laptop, i don't think if proper voltage is provided it would inversely affect its life.
Not allowing it to work is best option when car is not running as you'll see laptop giving warning "charger connected" then "charger removed"
seems the charger needs high amps to make it.
Old 29th April 2010, 00:30   #28
neutralgrey's Avatar
Thanked: 16 Times
Default Loose inverter connection
I know its been a long time since I had started this thread, my apologies in continuing the discussion now. But the thing is, its only today I could get an inverter. Its like the one Wildon mentioned about in the previous page(the one from MX electronics).
I have an issue and would like to know if any of you have faced it - The connection between the inverter and the socket doesn't seem to inspire confidence. Even though I haven't driven the car with the inverter attached, it looks like it could fall off at the slightest bump.
Any ideas on what could be done to solve this would be great. Will any DIY to fix it work? Like wrapping the insulation tape on the sides for a snug fit.
neutralgrey is offline   Reply With Quote
Old 29th April 2010, 08:59   #29
sathyaprakash's Avatar
Thanked: 44 Times
Please post some pictures of your car inverter to have a close look at it before advicing did you buy MX or any other chinease stuff?
sathyaprakash is offline   Reply With Quote
Old 29th April 2010, 21:22   #30
Thanked: 16 Times
Satya Prakash,
Its the same as the one Wildon had uploaded. Please see the pic below.
Attachment 248362
Ipod Nano, not charging from Cigarette lighter adapter rkbharat Gadgets, Computers & Software 7 8th April 2009 15:20
Cigarette Lighter for my bike? aveek Motorbikes 19 24th January 2008 01:17
FS:Sony Ericsson Car Charger Cigarette Lighter Adapter CLA-60 gmano Shifting gears 3 20th September 2007 19:52
indigo cigarette lighter fuse location shldn Technical Stuff 3 11th May 2006 12:17
Impact Wrench powered via Cigarette lighter, Opinions? s0uljah Modifications & Accessories 1 14th April 2006 00:03
