Old 23rd August 2005, 13:26   #1
Thanked: 7 Times
Unhappy Swift's Jerking Problem
I am experencing a strange problem that sometimes when i switch from 3 gear to 2nd gear Engine starts jerking(jhatka) for a while(about 3-5 seconds).
This occurs at between 18-25Km/h.
What can be the reason behind this?
Thanks and Regards
abhi1881 is offline   Reply With Quote
Old 23rd August 2005, 13:38   #2
revtech's Avatar
Thanked: 35 Times
does this happen only when you shift from second to third or otherwise also ??
try and leave the clutch gradually.
Rev
revtech is offline   Reply With Quote
Old 23rd August 2005, 16:22   #3
Thanked: 7 Times
This thing only happens in 2nd gear .Also I always leave clutch gradually.
Old 23rd August 2005, 17:00   #4
aseem's Avatar
Thanked: 419 Times
Please change the name of this thread as this is misleading to the prespective buyers. The name of the problem should be Swift transmission/gearing problem.
aseem is offline   Reply With Quote
Old 23rd August 2005, 17:10   #5
Thanked: 7 Times
yes definetly i agree with ur point.
How can i change the name of this thread?
Old 23rd August 2005, 18:39   #6
iceman91's Avatar
Thanked: 22 Times
hey,
swift has serious gearbox issues.
suzuki has messed up....as usual. had the chance to see one completely dissassembled and was pretty dissappointed by its design. cannot even be modded easily. pretty flimsy too.
if i am not mistaken a lot of swifts on the international market were recalled due to reverse gear not engaging...!!
iceman91 is offline   Reply With Quote
Old 23rd August 2005, 18:57   #7
Mpower's Avatar
Thanked: 1,687 Times
Welcome to the Jhatka club. Early Indica Diesels and early City VTECs also had the jhatka during downshifting. Methinks its a ECU calibration issue.
Iceman, gearbox same as Esteem na?
Old 23rd August 2005, 19:07   #8
iceman91's Avatar
Thanked: 22 Times
nah dude the swift has a complete new gearbox. the internals as well as the housiing differs.
Old 23rd August 2005, 19:08   #9
aseem's Avatar
Thanked: 419 Times
Its a different gear box... and no the Swifts were not recalled due to transmission issues, but due to fuel pump. The Swift gear box is better than Esteems or Balenos. I own Esteem and Swift so can vouch for this. Rest minor issues like reverse not engaging for some people are isolated incidents which might be due to the drivers fault. In any case please dont even think of comparing a Swift gearbox with Indica.
Old 23rd August 2005, 19:10   #10
iceman91's Avatar
Thanked: 22 Times
please check again the swift has had transmission issues.
Old 23rd August 2005, 19:18   #11
aseem's Avatar
Thanked: 419 Times
Swift was never recalled for transmission issues. The only issue I have come accross in this forum is that some people complained that the reverse gear was not engaging properly. This was due to the setup which most cars have which is different for the reverse gear as opposed to the other four. I am telling you from the experience of driving Zen, Esteem, Baleno and Swift that Swift gear box doesnt have that elastic feel of the cars mentioned, rather it feels power assisted and the gear changes are very precise. Some people who have driven Esteem/Baleno/Zen find it difficult to adjust to these gears, but this is a step forward not backwards and they do feel a lot better.
Old 23rd August 2005, 19:23   #12
SLK
SLK's Avatar
Thanked: 192 Times
I believe this must be with A/c only?... if so that happens in many cars! Not a problem.
SLK is online now   Reply With Quote
Old 24th August 2005, 16:42   #13
Thanked: 7 Times
Yes this thing happens only when the AC is ON
Old 24th August 2005, 20:23   #14
Thanked: 23 Times
i think aseem is right...the problem if any is there in the reverse gear only...that too not always...but the gear shift i must admit feels solid...and pricise...especially the small gear levers sporty feel
muni is offline   Reply With Quote
Old 25th August 2005, 19:06   #15
Xsailor's Avatar
I Ditto both Aseem and muni.
@abhi1881
A hunch - Check the clutch pedal. I got my Swift's clutch adjusted in the first 200 kms of operation as the pedal had 'sunk a bit' and causing engaging issues.
Xsailor is offline   Reply With Quote
Car jerking while accelerating adya33 Technical Stuff 32 24th May 2017 07:56
Engine Jerking Kary Technical Stuff 45 4th June 2016 13:27
palio jerking problems passionpurple Technical Stuff 21 8th February 2011 12:52
Safari Dicor jerking jyobeb Technical Stuff 15 10th June 2009 14:26
Jerking sound from skoda..please help me. jerish666 Technical Stuff 6 23rd December 2006 01:41
