Old 21st December 2009, 12:40   #1
Thanked: 9 Times
Question Maruti 800 immobiliser?
A friend of mine has gone on vacation and taken the keys of his 800, but has given some of us permission now to use the car. Putting the guy on skype video to his neighbors, I was able to get a keysmith to replicate the keys of his car. The duplicated key successfully opens the door and cranks the starter but the engine just won't fire up. Is this an immobiliser at work? How if possible can it be bypassed?
There is sufficient petrol in the tank, car lurches forward if clutch is released while car in gear at the time of cranking. Lights/power/reverse music work.
I believe it's a 2008 model.
Evil is offline   Reply With Quote
Old 21st December 2009, 15:54   #2
ranjitss's Avatar
Mine is 2003 model and does not have an immobilizer. I have tried starting with a duplicate key and it did start.
Yes, M800 - 2008 model do have immobilizers. The immobilizers in M800 were introduced in 2007, if I am not wrong.
ranjitss is offline   Reply With Quote
Old 21st December 2009, 17:05   #3
Thanked: 9 Times
What is the procedure to start it now? Call the dealer? How much would everything cost? I have full authorization from the owner and proof (can put the guy on videophone).
Old 21st December 2009, 17:57   #4
Thanked: 103,685 Times
Best for you to wait until your friend comes back. Yes, only a dealer will be able to procure a duplicate icats key for you. However, the dealer will need the registered owner of the car to fill out an application. He won't simply hand over a working key to you....would beat the purpose of the icats, would it not?
You serious? A locksmith was able to create a duplicate, upon seeing the key in a video?
Old 21st December 2009, 18:53   #5
Thanked: 9 Times
No he worked directly on the car through trial and error. What I meant was I put the owner on live video to obtain permission from the building's security/neighbors to allow the locksmith to work on the car.
The owner won't be back for a couple of weeks, do you have more information about this application procedure? Is it acceptable for it to be emailed/faxed back? Also, I understand this is an RFID based system? If I acquire an RFID reader+writer how practical is it to do the job myself? I'm willing to spend a few hours learning.
Old 21st December 2009, 19:21   #6
.anshuman's Avatar
Thanked: 9,159 Times
It the immobiliser (iCATS in Maruti lingo) working, its not possible to bypass the system easily, only a experienced car thief can help you. My advice is avoid it.
Swift DZire 2009 Immobiliser Lock Light Flashing vigsom Technical Stuff 7 10th June 2012 22:52
Help me with this immobiliser sans33 Modifications & Accessories 0 14th August 2010 18:39
Is the immobiliser technology different in different cars? n.devdath Technical Stuff 3 12th November 2009 18:59
After market immobiliser? sbasak Technical Stuff 1 19th March 2006 00:27
