Old 24th August 2006, 22:13   #31
DRC
DRC's Avatar
Thanked: 48 Times
I think this issue got raked up to help some one. And my problem is solved now.
Paint on Body, I just ignored. over a period of time, due to repeated washing and polishin, the paint dis appeared.
Wind screen, I was very disturbed to continue with the problem in this part, so after trying/learning all the options, finally I decided to change the wind screen, and did so. Not so much happy with the Asahi glass, which the Wind shield experts replaced. But the job those guys do is very professional and perfect. The quality of glass earlier had -Pilkington- was much better. Asahi tends to get water marks very soon. Glare is gone. so solved my problem.
DRC is offline   Reply With Quote
Old 24th August 2006, 23:06   #32
lamborghini's Avatar
Thanked: 1,667 Times
DRC,
when our fiesta got a small bumper dent, we got it repaired and painted but then the whole car became rough and always looked dirty.
It's been 4 months and it's still like that. How long did it take you? I am planning to get it done after monsoons along with the interiors.
Also guys,
in our corolla, some cement had fallen over the body and was later removed but now, when the car is driven in the rains at night and the wiper is on, it becomes really unclear and tough to see and there is a lot of glare. It is as though there is a coating over the windsheild.
What should we do? It's quite difficult to see for me so i guess its even worse for the drive (he's 68). The car travels 70km everyday so it's quite important too.
thanks.
lamborghini is offline   Reply With Quote
Old 25th August 2006, 03:19   #33
Sahil's Avatar
Thanked: 2,718 Times
@Lambo, try changing your viper blades that will make the vision better. I had a similar problem in my accord and felt the blades were fine but i took a chance and changed the blades and the glare has reduced alot! Also use a reputed companys windscreen/glass cleaning solution to get ride of grime etc that plus blade change should solve most of the problem. Remember to use newspaper to clean the glass with the solution NOT cloth.
Old 25th August 2006, 12:05   #34
DRC
DRC's Avatar
Thanked: 48 Times
Lambo, It took about an year, and I think 4 polishes (read waxing). I use Formula 1 wax.
The glass, I drive about nearly 10 months before replacing
wall paint splattered all over my car! pow3r2dawh33ls Technical Stuff 20 25th February 2011 10:53
I Grew Over Honda But Linea Grew Over Me !!! ManMachine Test-Drives & Initial Ownership Reports 125 3rd February 2011 12:26
From Humming @ Hampi to Jogging at Jog to going Gaga over Goa to ambling over Amboli vnabhi Travelogues 108 3rd December 2009 17:59
Fine paint spots all over - need help Rover Technical Stuff 8 23rd August 2006 13:55
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
