Old 24th December 2009, 19:28   #1
monster2's Avatar
Default Opel Corsa 1.4 Gls Low Pickup And Sluggish
Hi Team,
I was Looking out for some advice here, I have Opel Corsa 1.4 2002 model, I have got it decarbonized and Even Replaced with new Air filter(Stock), however the pickup is too low and even Sluggish when the A/C is On, The Car has genuinely done 42000KM, however the exhaust completely worn out is leaking, I wanted to make sure, does changing it will really make any difference or Its any other issue, and The FE is really good close to 12km.
I however did checked with GM Service station he said all Corsa are the same, however I do feel it cant be so low.
monster2 is offline   Reply With Quote
Old 24th December 2009, 20:52   #2
vigsom's Avatar
Thanked: 610 Times
Originally Posted by monster2 View Post
Hi Team,
the pickup is too low and even Sluggish when the A/C is On, The Car has genuinely done 42000KM, however the exhaust completely worn out is leaking, .
After completing which job on the car have you been feeling this?
please get the catalytic converter checked - it could have fallen apart leading to a partial block in exhaust
you could also get the throttle body cleaned;this on-line decarb is not advisable
Old 24th December 2009, 21:33   #3
vdiatech's Avatar
+1 to vigsom
take it to any local exhaust place. ask them to remove the CAT-CON and replace with a straight pipe.
vdiatech is offline   Reply With Quote
Old 25th December 2009, 07:27   #4
monster2's Avatar
@Vigam- The Car that I have bought is a Used one, however I have had this car since sometime and the car doesnt give any probs except the Low pick, I mean to say nothing has reduced the pickup, its just that I have seen other corsa's around zooming and min still tries to catch up them. I have got both throttle body cleaned as well as debcarb done
@ Vdiatech I do get to the point what you said about the Cat Con, But will it effect the Piston if I do so or reduce the mileage, coz what you said really makes sense as not to Compare but I have a Cat Con Shogun and I changed it will Old Non Cat Con exhaust and it changed massively in terms of Pickup.
One more thing Buddy My car has and exhaust which is with Bent pipe at the end the old Model I hope you get it, however I saw couple of corsa in which the exhaust tail in not bent and is visible. I hope this gives better explanation
Dead Spot, Sluggish Performance, Low Torque in Zen LXi frankmehta Technical Stuff 27 2nd April 2010 23:14
Lancer Sluggish at low RPMs leadf00t Technical Stuff 17 14th April 2009 19:00
Low mileage, less pickup and judder while reversing, what can be the issue here? kaushik_s Technical Stuff 40 3rd October 2008 22:14
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
Opel Astra Club or Opel Corsa bsashwin Sedans 2 11th July 2006 17:34
